Another fresh air intake option
Old 01-17-2013, 12:15 AM
George Ries
George Ries's Avatar
Originally Posted by 77C34SPD
Measure a couple of times,lots of masking tape and have at it. If I screwed up,would have been a perfect excuse for an L88 hood
thats a good way to look at it
Old 01-17-2013, 11:17 AM
scrappy76
scrappy76's Avatar
Quality job, very nice. Its your car enjoy.
Old 01-17-2013, 11:36 AM
MrJlr
MrJlr's Avatar
Nice job
I always LOVED the "Shaker" Mopars.....
Old 01-17-2013, 03:16 PM
redman76
redman76's Avatar
St. Jude Donor '09
I like people who are always trying new things. I agree that it would look good with a stripe. Good job getting done in two days! I've been thinking about CAI options for two years now and still not sure how I want to do. I'm thinking of doing something similar to the stock setup, but with 14" filter, drop base and modified to fit with RPM intake. I just need to get the cardboard and fiber cloth out and start creating.
Old 01-18-2013, 02:44 AM
tommycoffey
3rd Gear
tommycoffey's Avatar
Two thumbs up for that. Look cool
Old 01-30-2013, 11:46 AM
myohpe@gmail.com
myohpe@gmail.com's Avatar
I had a different approach to cold air intake on my '79. I went with cowl induction. You just have to be willing to cut a hole in your cowl. I was, since I can always fill it if I ever wanted to change it back(I don't think so!). It fits under the stock hood (1/4" clearance) and works Great - all for under $170! I have solid motor mounts, so engine movement isn't a problem. I have an Edelbrock carb, Performer RPM manifold. I used all Spectre parts - polished aluminum 4 inch system - capable of over 900 cfm flow. Parts: #9849 4" plenum, #9604 4" velocity stack, #9709 4" x 4" tube, #9749 4" 45 degree elbow, #9776 4" couplers(3), #4208 low profile air cleaner nut. A real increase in acceleration vs. my previous Edelbrock foam carb-top filter. I use a SS screen filter, between the velocity stack and straight tube, but you could place a foam one somewhere in the system. I had no idea it would work as well as it does, especially when the engine gets warm! BIG Power increase!
Here is a view of it now:
And this is what it replaced:
The entire install took about one hour, including cutting a 4.5" hole in the cowl. It works perfectly in my 1979, but since Corvettes changed hood/cowl setups over the years, you will have to do your own measuring to be sure it will fit under your hood. Specter has complete dimensions listed on their site for all of the components. Have fun designing your own system!
Old 01-30-2013, 11:59 AM
7dSHARK
7dSHARK's Avatar
STILL IS! Just my opinion
Old 01-30-2013, 01:34 PM
bashcraft
bashcraft's Avatar
Originally Posted by myohpe@gmail.com
Now that, I like!
Old 01-30-2013, 03:59 PM
captl27
captl27's Avatar
I like the out of the box thinkng. Another Neat clean job. I had to make something that worked with my Duel 600's.
http://forums.corvetteforum.com/c3-t...uel-fours.html
Old 01-30-2013, 07:32 PM
John 65
John 65's Avatar
Nice job, its different. I like it. Clean.
Old 02-04-2013, 04:58 PM
captl27
captl27's Avatar
I like our intakes as much as these http://forums.corvetteforum.com/c3-t...take-done.html
Old 03-10-2013, 01:19 AM
eagle275
Support Corvetteforum!
eagle275's Avatar
Wow, some nice work on all of them! Great ideas too!
Quick Reply: Another fresh air intake option
