amp problem
I had the same happen on my 82, the voltage regulator in the alternator was bad. Replaced the alternator with a heavy duty from NAPA and it solved the problem.
Andy
Andy
Do you know how to remove an alternator and take it apart? Replace the voltage regulator inside the alternator. Not difficult. The voltage regulator is the unit that has the two terminals that stick up that the connector plug attaches to. You will need to suspend the brushes in a retracted position to assemble the alternator. I toothpick will work. After it is assembled remove the toothpick. Pay attention to the insulated screws that retain the voltage regulator. Over the years in maintaining my original owner 1970, I have replaced the voltage regulator a few times.
How much "overcharging" are you talking about? When the battery is fully charged, the alternator still puts out nearly 13 volts. You will never see an auto alternator putting out only 12 volts...unless the idle is so slow that it can't develop a charge.
If it overcharges to nearly 15 volts, the regulator [in the alternator] isn't functioning.
1st take a multi meter and test the true output of the alt. that way you know your not just throwing money away. start the car and test at the batt,or at any conveniant pos/neg place.If your charging over 14 volts your reg is prob bad. you can buy a new chrom alt 120 amp on e bay for about 70 bucks skip white. good luck. always test before you replace.
Andy
amp problem
Thanks everyone for the help having the altenator rebuilt . The Problem I'm having now is the passenger seat will not fold down it seems to be caught on the inside near the center consol . I want get it out to have it reupholsered . Thanks again
Lot of misinformation out there, 14.5V is fine for alternator output measured at the battery with the engine running, should have put a voltmeter on the battery first before having things rebuilt or replaced.
The range for a good alternator at about 1000 rpm's is 13.7 to 14.2 measured at the +12vdc terminal on the back of the alternator to ground on the alternator with a digital volt meter. At the battery expect .3-.5v drop due to line loss of the cables and connectors. Beyond 14.2 get a new one as you will cook the battery!
