OBX Sidemount headers
Old 12-10-2012, 06:24 PM
findley87
findley87's Avatar
Default OBX Sidemount headers
looking to buy a set of OBX sidemount headers, has anybody bought these, what do i need to look out for,do they fit, had a set of hooker they rusted out in one year.OBX are stainless.
Old 12-10-2012, 09:06 PM
racegofast
racegofast's Avatar
I bought the standard long tube stainless ones and they hung down about 2 inches more than they should, It was bad enough I had to replace them with some shortys. Be very carefull good luck
Old 12-10-2012, 09:54 PM
MikeKey
MikeKey's Avatar
They're not the same quality as say a set of Hookers, but the price is worth the extra work. Some people have a few minor fitment issues, others none. Do a search, well discussed. They're great headers.
Old 12-10-2012, 10:13 PM
Learning_Curve
Learning_Curve's Avatar
Only issues with mine are that the side tubes are closer to the frame at the rear than at the front and the bolt holes on the flange didn't want to line up easily. I would buy a set of Fel-Pro gaskets and check the flange holes before attempting to mount them.
Oh, and now I have the problem that they make the rest of car look bad by comparison.
I'll work on fixing that...
Old 12-10-2012, 10:16 PM
racegofast
racegofast's Avatar
Default where you get those wheels????
Old 12-10-2012, 10:24 PM
Learning_Curve
Ebay
American Racing Daytona. 18x9 5"bs rear, 17x8 4.5"bs front. I've only been able to find pics of them installed on one other vehicle.
Old 12-11-2012, 07:21 AM
JimT
JimT's Avatar
You will have installation issues. Access to a lift is very helpful. Check header flange fit to heads first. I fought mine for several days (and visits to a muffler shop for "pounding") before mine could be installed. Make a template of the header flanges for both sides (bolt holes and port slots) and and place on heads to check alignment accuracy. Then attempt to place your header bolts into the header flange bolt holes to see if they can actually be inserted - and if the bolt can be inserted, check to see if you can access the bolt head with a wrench (some of the pounding I mentioned earlier). I had to fabricated a special wrench so I could tighten my head bolts. Once installed they do look good.
Good luck.
Old 12-14-2012, 02:40 AM
Dante7
Dante7's Avatar
Mine fit perfect without a problem! Set of sweet thunder inserts and I could not be happier
Old 12-14-2012, 12:16 PM
bdchase73
bdchase73's Avatar
Have the SS hooker headers myself and side pipes. I was lucky enough to do this when the body was off the car, so all in all it was not to bad. However, after I got everything back together, looks like it would be a pain to do with everything in place.
Old 12-14-2012, 10:02 PM
palmbeachvette76
palmbeachvette76's Avatar
A lot of the installation problems will depend on how straight the body is and how centered on the frame it is. My installation seemed to lean towards the worst case scenario though I'm sure there could be worse out there.
First thing that I found out was the bolt holes were not drilled 100% accurately. I had to elongate (wallo out) the second holes in order to get the bolts to start. You will want to use longer bolts since the header flange is 3/8" thick but on the holes where the pipes make a sharp bend you'll use the standard length bolts here.
The second problem will be the rocker moldings and whether they will go back on in one piece, two pieces with with some trimming. Also the rear of the side pipe (exit tube) tends to bow inward towards the frame. I had to cut my rocker moldings into two pieces and grind them down to conform to the tube shape. One screw holds the front section in and the remaining screws hole the rest. Unless you get on all fours you can't tell what I did since I took my time making cardboard molds as guides to modify the rockers with.
Everything else was good. No hitting the idler arm or steering box. A/C bracket for the Vintage Air I installed only needed a slight grind on the spacer tube since the pipes are larger in diameter. I did run into a problem getting a spark plug socket on #2 spark plug but the rest were fine, a little bit of a challenge but went in fine.
So the bottom line is what kind of tools do you have and what is your mechanical experience. If you can think creatively and fabricate a little bit then you'll be fine, if not search for a shop willing to take on the install and let them handle it.
Old 12-15-2012, 07:11 AM
JimT
JimT's Avatar
Good response Palmbeach, your "creativity" statement is right on. Also, had I not had access to a lift and a great selection of tools I couldn't have completed the install.
To OBX Sidemount headers
Quick Reply: OBX Sidemount headers
