Block number identification
Recently purchased a 76 L48 driver. I'm not sure if I have a number matching car or not. Here are the numbers off the right front of the block deck. . . < 16S420775 > and < V0126CKX >. Can anyone disifer these for me and is the VIN needed also?
Thanks guys.
Thanks guys.
Received 1,469 Likes
Cruise-In II Veteran
VIN derivitive stamp.
1 Corvette
6 model year (76)
S plant code for St. Louis, Missouri
420775 consecutive unit number.
If your VIN is 1Z37L6S420775, you're good.
...V0126CKX...
V plant code for Flint, Michigan engine assembly plant
0126 date engine was assembled at Flint (January 26th)
CKX engine suffix code identifying a Corvette L-48 with auto trans
Sound like your car?
1 Corvette
6 model year (76)
Engine stamp.
1 Corvette
6 model year (76)
Engine stamp.
That's my VIN. Guess I've got a match, thanks so much.
What model automatic would have been original??
Received 2,878 Likes
Hi M,
I believe the 350 Turbo was std with the base engine (L-48) while the 400 Turbo was std with the optional engine (L-82).
Regards,
Alan
Regards,
Alan
