factory side pipes
factory side pipes
Trying to mount factory 69 side pipes on my 70 vette / Need the best method to do it . I have the exhaust sidepipes mounted already , just need to figure how to mount the shields. Do you leave the 70 rockers on and bolt the insulators and shields setup to the rockers? If so would like to find a pair of used 70 rockers that I can customize. Thanks
Received 1,469 Likes
Cruise-In II Veteran
Received 2,878 Likes
Hi 70,
The side-pipe shield needs to be installed before the side pipe.
The large forward bracket on the shield can't slip into position with the pipe in place.
I needed to drill new holes too.
I test fit both the pipe and shield before drilling any holes. If the shield is mounted too high on the rocker channel the bottom of the pipe is visible.... not a good look.
Regards,
Alan
Regards,
Alan
Hi 70,
Regards,
Alan
Regards,
Alan
what he said...
While I was able to get the shield on after installing the side pipes it indeed took very careful manipulation of the shield to get the front started and then swing the rest into position. Pipes last would definitely be easier. And my shields are mounted as high as I could get them to cover the rocker area which does leave the lowest portion of the pipe exposed.
what he said...
If you have a 70 assembly manual, you may want to look at the accessory section, in the back. It seems to me that the 70 AIM had a section on installing the factory side pipes, with the page marked "cancelled". I think that Chevrolet contemplated offering the side pipes on the 70 Corvette, but cancelled the option, just before production started.
Hi,
Here's what I felt was a reasonable compromise between having the pipe covered and the shield at an acceptable height.
These are 69 shields painted black.
Regards,
Alan
Regards,
Alan
Question?
Height looks nice, did you have to alter the front shields or did you need to alter the cars body ?My front shields are going to be hiting the front of my body ? (ROCKER PANEL AREA)
Hi 70d,
Yes, the forward end of the fiberglass rocker panel needs to be cut for both the pipe and for the shield.
Regards,
Alan
Regards,
Alan
install
Got the shields "mocked" in today after trimming out what needed to be, ordered new retainers an screws.now we wait patiently. But my wife says ,I'm not to good at that.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a step by step with the AIM page info too...
http://willcoxcorvette.com/repairand...lp.php?hID=199
install
Holy Mackeral, I'm kinda of a computer illerate, but I followered your illustrations that you sent earlier,along with everyone elses suggestions. Waiting for my new screws an retainers to arrive. Thank you and to everyone else. I really appreciate it
