ZZ4 break-in completed, and all I can say is ....
Old 06-09-2002, 10:04 PM
Dave68
Dave68's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (Cali,77,L-82)
I wish I had the forethought to get the ZZ4 before I had the original motor rebuilt :cry At the time I was more concerned with matching #'s but now if I blow the motor I am butt out. I could have bought the ZZ4 and kept the original block on a stand in the corner of the garage until it was needed for resale....Well if you guys get too old for the excitment let me know I'll take the ZZ4 off your hands. :lol: :lol: :lol:
I rebuilt (and had rebuilt) my 327 a couple of times before I called the local Corvette shop about a cam change to pass the smog test. The owner recommended that I drop in a ZZ3 instead. He told me that that you can get good numbers from a mix-and-match rebuild, but if you want consistent, long-lating (durable) power, go with a crate engine - you won't be sorry. Thankfully, I listened to him and had the ZZ3 installed. Result: 290 RWHP and a blast to drive.
Congratulations!
Old 06-09-2002, 11:00 PM
mg62
mg62's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (Dave68)
But Dave, why'd you get rid of the '68?
Old 06-10-2002, 12:48 AM
theandies
theandies's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (mg62)
Hey John, no risk of me trying that myself!
Anything can be done in your garage if you have the proper tools and someone you can fall back on for tips and advise. I personally have never rebuilt a posi rearend so I would be no help to you as far as what tools and techniques needed (I am sure forum members can help here). I know that a friend of mine has a 98 Camaro SS and he had his gears changed to 4.11's and had a well respected shop do the work, well three sets of gears later they work just fine. He even used GM gears because of the fact that he was told and researched that some of the aftermarket gear companies gears were noisy and that the GM gears were not. I don't know how different these new rearends are that ours but I don't think they would be that different.
John
Old 06-10-2002, 02:02 AM
VetteNut72
VetteNut72's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (theandies)
John,
If I have to keep looking at your signature I'll have to throw out the white paint I just bought and go buy some war bonnet yellow. Looks Great!
Craig
Old 06-10-2002, 09:54 AM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
I am very impressed with my ZZ4. This motor rocks! The first time I stopped to fill up with gas I left the station sideways. Now if I can just solve the carb problems. Does anyone know what would cause a carb to go lean at around 4k rpm??
Mark B.
Old 06-10-2002, 10:05 AM
77-4speed
77-4speed's Avatar
If you're thinking about changing the gearing, check out this website:
http://corvetteperfection.com/corvetteperfection001.htm
They rebuild your rearend and will swap out the gears at no extra charge! The cost for the rebuild is extremely well priced at $375. Of course, shipping freight is going to cost a pretty penny, and you'll have to pull the diff yourself, unless you want to drive to Beloit Wisconsin.
Old 06-10-2002, 10:06 AM
theandies
theandies's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (VetteNut72)
John,
Craig
:lol: :lol: :lol: :lol: I like it, didn't care for it much at first but now it will always be WBY.......Thanks for the compliment. It's funny my wife and I were talking about changing the color a while back and #1 on the list was white.
John
Old 06-10-2002, 10:13 AM
MikeC
MikeC's Avatar
Hey MG, how much did that ZZ4 set you back in our canuck bucks?
Old 06-10-2002, 10:44 AM
mg62
mg62's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (MikeC)
Mike, the Cdn. list price on the ZZ4 is $6899. Ouch!! The best deal I could find is at John Bear Pontiac in Hamilton. Here's their website, showing the ZZ4 at Cdn. $5495. This is as good or better than the best deals from U.S. places like Sallee Chev.
http://www.johnbear.com/crate_engines.htm
Nikki Cupit is the parts manager at John Bear, and she's very helpful. She had the engine delivered straight to my mechanic, free of charge, 2 days after I ordered it.
Old 06-10-2002, 10:48 AM
Alwyn678
Alwyn678's Avatar
Honey, you've gotta do a load o' laundry, 'cause I need new underwear ....
Unbelieveable!!! The torque is amazing, both off the line and when you go WOT while already at speed. The scream of that engine when you stomp on it is like being too close to the Shuttle launch pad.
I strongly recommend to anyone thinking about getting a ZZ4 for the Vette ... RUN DON'T WALK TO YOUR GM GOODWRENCH DEALER NOW!
Line up beside me now, ricers. That's it. A little closer .... Let's have some funnnnnn .....
Congrats.....What did you do with the original engine?? You can make it just as strong.. :yesnod:
Old 06-10-2002, 04:40 PM
VetteNut72
VetteNut72's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (Alwyn678)
quote:
____
____
If you are real good or have a good engine builder then maybe...
Most of us don't have the 'short block' experience needed to build a strong reliable bottom end and the ZZ4 is an excellent choice for the majority of C3 owners. Advantages include:
-Short Block-
New one piece rear main seal block
Roller cam and lifters
Steel crankshaft
Hyperu pistons
Powdered rods
-Complete Engine-
Aluminum center bolt heads
HEI Distributor
Decent dual plane intake
The complete engine listing shows parts you would be buying anyway to upgrade and old two piece rear main seal block with a non-roller camshaft. Add a steel crank, good pistons, camshaft and lifters and you can start to see the positive side of a ZZ4 swap.
Don't get me wrong, building a strong and reliable short block is a viable option and can be rewarding but not for most of us. Some have one built by the local shop or engine builder but this at least doubles the cost of doing the work yourself. And can you trust this builder to do what you want. This level of trust is usually proportional to the amount of money spent but not always. I had previously had two engines built that I was unhappy with before I installed the ZZ4. I'm sure many people can tell stories about problems with engines that they had built for them (New topic anyone?).
For those who can build a good engine themselves or have the bucks to have a good one built, then I applaud you, but for the rest of us the ZZ4 is a better choice.
Old 06-10-2002, 05:23 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
That's exactly it. It's scary. But ... fun scary.
I wonder if I'm going to be scared about the power of my new engine. I had a 450 HP in my 69' (sold) and it didn't impress me all that much. OK - It felt much stronger than the 350 HP engine that I had before but it wasn't really what I expected... Will see if my new engine will manage to impress me (or even scare me)!!!
:cheers:
Olivier
Old 06-10-2002, 06:35 PM
  #33
Dwayne 76
Dwayne 76's Avatar
Mark, I meant to tell you this on Sunday; every time your car shifts there is a puff of black smock out the tail pipe. I'ts not a lot, but enough to notice. I don't know it thats normal, not trying to alarm you.
Old 06-10-2002, 09:41 PM
  #34
mg62
mg62's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (Dwayne 76)
Hmmmm ... no, I didn't know that. Anyone know what that might be about?
Old 06-10-2002, 09:46 PM
  #35
1Bad69
1Bad69's Avatar
mark...i noticed that too but was just reminded about it after reading dwayne's post....
Old 06-11-2002, 01:28 AM
  #36
theandies
theandies's Avatar
Default Re: ZZ4 break-in completed, and all I can say is .... (1bad69)
Sounds like your running a little rich to me. Black=rich White=lean
John
Old 06-11-2002, 09:10 AM
  #37
mg62
mg62's Avatar
John
Thanks. The car happens to be in the shop today, so I'm getting my mechanic to check it out.
To ZZ4 break-in completed, and all I can say is ....
Old 06-12-2002, 02:12 PM
  #38
Cali,68,L-79
Cali,68,L-79's Avatar
I saw the Eldebrock crate 350 HP engine for $4999.00 and the 450 HP engine for $5999.00 both these use a hopped up ZZ4 sounds better to me for less. Check on Eldebrock/ SUMMIT websites.
Your thoughts?
Old 06-12-2002, 02:24 PM
  #39
MikeC
MikeC's Avatar
Mark was talking Canadian dollars, so those engine you specified, by the time we paid exhcange, duty and other crap would be around $10,000
Lets just say from my local GM dealer an Goodwrench engine for my truck was going to cost me $3500CAD
Old 06-12-2002, 02:32 PM
  #40
Cali,68,L-79
$3500.00 for the ZZ4 or just a regular 300HP version?
Quick Reply: ZZ4 break-in completed, and all I can say is ....
