Rear sits to high with new spring
Old 11-18-2012, 10:00 AM
tyrant
tyrant's Avatar
Default Rear sits to high with new spring
I just installed a TRW composite spring. The rear now sits around 31" to wheel well lip. My '75 is around 28". The bolts are at the lowest adjustment. Any ideas?
Old 11-18-2012, 10:09 AM
hugie82
hugie82's Avatar
Use longer spring bolts???
Old 11-18-2012, 10:24 AM
cottoneg
cottoneg's Avatar
I am not sure why this topic has come up so much. My only guess is that we are not getting our springs from Chevrolet and specifications vary from manufacturer to manufacturer.
As to what to do about your rear of your car being to high and how to lower it, set you “D height”. I purchased 10 inch bolts, set my D height and then cut the excess bolt with a dremel.
Here are a couple of links to help:
http://forums.corvetteforum.com/c3-g...de-height.html
http://forums.corvetteforum.com/c3-t...-car-look.html
http://forums.corvetteforum.com/c3-t...-back-end.html
Hope this helps.
Old 11-18-2012, 10:48 AM
76Vett
76Vett's Avatar
The car will settle some. I rolled mine back and forth a few times and it settled almost an inch. Took it for a 25 mile ride and it settled almost another inch - ow withing a 1/4 inch or its original height. Might give that a try before purchasing longer bolts.
Old 11-18-2012, 11:28 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
I installed 1" longer bolts and the rear dropped almost 2".
Old 11-18-2012, 12:07 PM
Sidepiper
Sidepiper's Avatar
1. Roll your car back and forth, push down on the rear of the car.
2. Did you tighten the 4 bolts on spring retainer while the car was up in the air?
3. Install 8 inch bolts.
Old 11-18-2012, 12:17 PM
tyrant
tyrant's Avatar
I'm going to roll it back and forth. Lots of horror story's with these spring!
I did tighten when in air. Correct or no?
Old 11-18-2012, 12:42 PM
Mooser
Mooser's Avatar
Received 3,134 Likes on 2,068 Posts
No
If your talking about the 4 bolts on the diff, they must be tightened with the spring loaded.
The two out at the end to the T/A don't matter
HIH
Mooser
Old 11-18-2012, 12:55 PM
tyrant
tyrant's Avatar
Guess I better recheck them. So I made them too tight?
Old 11-18-2012, 01:09 PM
Mooser
Mooser's Avatar
I believe the problem of tightening them unloaded is the torque on the bolts is being used to pull the spring flat to the diff rather as opposed to when it's loaded the weight of the car is pushing it flat and the bolt torque is fully applied to tightening the spring
Exaggerated heavily, if the spring is unloaded and the bolt torqued down and it didn't quite pull the spring flat, when the car weight went on and flattened the spring the rest of the way, the bolts would actually be loose.
In theory this could affect the ride height, but I wouldn't think it would be much if anything.
Mooser
Old 11-18-2012, 02:52 PM
tyrant
tyrant's Avatar
They are 8" bolts which bothers me even more. Heres some pics
Old 11-18-2012, 02:53 PM
tyrant
tyrant's Avatar
Old 11-18-2012, 02:56 PM
Doug1
Doug1's Avatar
other then weight reduction, all these threads of guys having to wrestle their rear end back down to previous levels, these springs just don't seem to be worth the hassle?
Old 11-18-2012, 04:21 PM
Tim H
Tim H's Avatar
I wouldn't buy one along time ago because of this.
No one needs a car to sit that high so why does the company keep making them that way?
You shouldn't have to add longer bolts to drop it down, instead they should be used to raise the rear end up like other cars and their air shocks do.
Old 11-18-2012, 04:27 PM
tyrant
tyrant's Avatar
I agree. Why can't we just bolt these on? Wasted a ton of time
Old 11-18-2012, 04:44 PM
7T1vette
7T1vette's Avatar
The springs with higher spring rates should be formed a little flatter, since they won't compress as much under the same vehicle weight. I'm not sure all manufacturers take that into account. Most folks, using their C3 for normal street use, should not select the high spring rate monosprings.
Old 11-18-2012, 05:16 PM
tyrant
tyrant's Avatar
When I ordered it I asked for a as close to stock as possible replacement that would not affect ride height
To Rear sits to high with new spring
Old 11-18-2012, 05:24 PM
Doug1
Doug1's Avatar
i can understand there being problems if you've removed a lot of the steel from rear bumper and thus lightened the original intended load, and/or gas tank mods to lighten as well. but that wasn't the case here. problem is too, cuzz mine went up quite a bit when I lightened the rear(much of rear bumper steel, 5mph shocks and entire spare tire assembly), is it throws the handling way off. when I got mine back down, it handled more like a sports car again, didn't feel like rear end wanted to fly out from behind me on hard turns
Old 11-18-2012, 08:52 PM
'75
'75's Avatar
I've never used one of these springs, but in the pic it looks like there is a spacer on top of the spring at the diff cover, could one of the spacers be moved to the bottom and let the car sit lower?
Old 11-18-2012, 09:13 PM
76Vett
76Vett's Avatar
Just looking at your pic and see that you don't have 'slotted' nuts on the spring hanger bolts. It's not much but looks like you could lower your car 1/4 inch plus using that nut. (not sure what they're really called)
Quick Reply: Rear sits to high with new spring
