Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-16-2012, 09:37 AM   #1
Last Special
Junior Member
Default TH400 Replacing TH350 Question
I'm thinking of replacing my TH350C with a TH400 in my 1980 to handle the 550+ HP 400ci small block performance engine. Correct me if I'm wrong, but I believe a new shorter driveshaft with stronger U-joints will be needed, as well as stronger half shafts. All I have now is a dual trans crossmember. What do I need to know to make the change? A 700-R4 was considered, but a stock 400 is probably as strong as a moderately built 700. I also was told that the 700 is a little too wide to fit between the C3 dual exhaust pipes. Any suggestions or other help on any of these points would be appreciated.
Thanks,
Ric (Last Special).
Last Special is offline   Reply With Quote
Old 11-16-2012, 10:24 AM   #2
gkull
CF Senior Member
gkull's Avatar
The pan on a 700R4 is wider. so for clearance i custom built a crossmember for the exhaust to pass under (Not through) the crossmember. BT overdrives sells a pass under Cross-X
A 400 tranny can be built to withstand over 1000 hp.
Unless you are drag racing or only have one leg, I would question why anybody would not want a manual tranny
gkull is offline   Reply With Quote
Old 11-16-2012, 10:56 AM   #3
Matt Gruber
CF Senior Member
Hi gkull!
I like the stick in my 61,and wished my 72 had a stick. I HATED the TH400 at first, the shifts were all WRONG.
But, with the governor recalibrated, it now shifts at 5700 in Drive. and of course it NEVER shifts late at WOT(i've been late sometimes in my 61 and hit 7000 instead of 6k). And with the adjustable vacuum modulator it kicks down instantly to 2nd.
and the "paddle" switch on the console lets me go back to 1st electronically coming around a tight corner. Plus the GREEN light on TOP of the dash lets me paddle shift at an earlier rpm(with the gas pedal) at WOT. So i really like it, with the mods.
Matt Gruber is offline   Reply With Quote
Old 11-16-2012, 05:26 PM   #4
diehrd
CF Senior Member
diehrd's Avatar
If you are only gonna race it or only drive in short hops I would stick with a TH400,, if you plan on driving it a fair amount including distances I would not use anything less then an O/D, and in my opinion if streetability is important your hp of 550 plus may be to much with a carberated engine to have street manners. ( Idle and vac issues should be quite fun) and the stall converter you will need to keep it happy will make all standing starts feel like a standard with a slipping clutch.
Alsoi with that kind of power you also should look at changing the rear end totally including half shafts and joints . I am pretty sure an aluminum differential will go off like a bomb at some point during hard acceleration
And the 700R4 will fit like a glove in the tunnel , if you go that way get a cross member from bto and google shifter detents for the company who makes your 3spd stock shifter a 4spd shifter
diehrd is offline   Reply With Quote
Old 11-17-2012, 11:50 AM   #5
Matt Gruber
CF Senior Member
if u built the 400sb for say ~450hp the TH400 would fry the tires w/3.08 stock stall 2100, or 2500 for sticky tires.. no need for OD. less breaking the driveline and more driving fun. Then if u get the urge to break parts, add 100 shot of nitrous.
Reload this Page TH400 Replacing TH350 Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
