Lowering ride height...what would you do?
Hi Folks,
I posted this question in the C-2 section with not much response.
I have a '64 fastback with donor disk brakes from a '69. I am looking for more ride height adjustability (lower) in the front. Can anyone here tell me if the QA-1 coil overs or an R&P setup (steeroids) would be the best choice? Both manufacturers claim height adjustability but I want to hear from someone who has installed them and what are the results. I've already cut down the front coils but don't want to lower the car that way anymore.
TIA
TIA
You're not getting much response here either. I don't understand how a rack and pinion can lower the ride height so I'm lost on that one. As far as coil overs go why not call Van Steel and ask for their expertise? I'm sure there is some adjustment in their coil over system. You can also consider VB&P mono spring as the height as well as the rate are adjustable. I am by no means a suspension guru but keep in mind the lower the ride height the more spring rate you need to keep from bottoming out. Hopefully some of the experts will chime in soon.
Yes Sir' I installed a new rear 330 # composite spring with 8 " bolts, & a set of 460 # front spring which is already 3/4 " shorter form V. B. & P. I. it is low now. But when I take off ( Jack rabbet starts, ) It does not squat, it just goes. I love it, but it is a little rougher on the rough roads. Gene
you threw me on your question.
The steeroids doesn't change ride height, but bumpsteer can be adjusted when you change the ride height with the steeroids system. clear as mud? Specifically, there are spacers that change where heim joint intersects the bolt that ties to the steering arm. Thus, it's adjustable FOR any given ride height.
QA1s, I've not used them on Corvette, but on several other vehicles and I like them. From my experience, they are well-engineered, and robust coil overs. With that said, I'll normally keep my spring and my shock separate because there are more options in both spring rates and shock rates than QA1 has available. It is nice to have adjust-ability, but in all honesty, I've might have changed them once after I set the initial ride height.... so have the ability to change is valueless to me.... and it does cost money.
If you're looking to constantly adjust the height, air ride is the only choice because it's so much easier, the parts cost the same, and you don't get dirty (or lose the tool) when you want to change the height.
