What is this relay for?
Old 10-26-2012, 01:04 PM
AirborneSilva
AirborneSilva's Avatar
Default What is this relay for?
I found this on the inside of the rear compartment that the jack goes in (or would if I had one), can anyone tell me what it operates?
Old 10-26-2012, 01:35 PM
FreshSelect
FreshSelect's Avatar
does it have a part # on the relay itself... it should have one, and thats if it is legible...
Old 10-26-2012, 01:36 PM
AirborneSilva
Looked but couldn't see one
Old 10-26-2012, 01:49 PM
FreshSelect
what year is your vette? I will check my 79 to see if i find something there..
Old 10-26-2012, 01:55 PM
KenSny
KenSny's Avatar
Part of the alarm system.
The AIM shows all the parts.
Old 10-26-2012, 01:57 PM
AirborneSilva
I always for get to post year, sorry, it's a 76 but it looks like Ken has the answer. Thanks guys!
Old 10-26-2012, 03:36 PM
FreshSelect
awesome kensny! glad that somebody was able to help you. I was going to try, but thats good someone jumped in.
Old 10-26-2012, 03:58 PM
redrdstr72
redrdstr72's Avatar
There should be a flasher switch right next to it, yes? Looks exactly the same as the turn signal flasher. Together, they operate the alarm. The relay stores/sends the signal and the flasher gives the intermittent "beep" to the alarm's audible horn.
Does your alarm work?
Old 10-26-2012, 04:24 PM
AirborneSilva
I do appreciate your help, as Kensny help. these forums save a lot of frustration!!
Old 10-26-2012, 04:27 PM
AirborneSilva
I was wondering what the other plug there was for, it does have the dual connection that are angled like a flasher, sadly no the alarm does not work and the "key" switch has some serious bubba work done so I am going to replace that and will have to figure out what else bubba did to the alarm system too.
Thanks for your reply and extra input, every little bit helps
To What is this relay for?
Quick Reply: What is this relay for?
