Leaf Spring Washers
Leaf Spring Washers
My leaf spring decided it want to pop on me the other day. The washers are bad and that is what caused it. My question is what size are these flat washers? I can not justify the shippng on these from vendors if I can get them local. Thanks in advance.
http://www.ecklerscorvette.com/corve...1963-1982.html
I just need the washers. I ordered poly bushings through summit cheaper than the vendors want for them. I bought the rubber kit 6 years ago and the quality of the rubber and the washers is junk. The bolts i did not use because my original bolts were in great condition and seemed better than the kits. Cups are fine. Seems it is just a 1/4" thick flat washer with a 9/16" opening for the bolt. I will check with fastenal in the morning.
Received 2,878 Likes
Hi,
Very interesting first post from thindseo12 !?!
Regards,
Alan
Regards,
Alan
