window adjustment
Old 09-28-2012, 08:03 PM
corvette1982
1st Gear
corvette1982's Avatar
Default window adjustment
put in new window motor, window does not go all the way up. are there any adjustment to correct this?
i can pull the window up where it is suppose to be, but then it will not go up or down, still sound like window stop?
Old 09-28-2012, 08:29 PM
69FASTFUN
69FASTFUN's Avatar
Check the window stops.
Old 09-28-2012, 10:49 PM
Doug1
Doug1's Avatar
If door is open(no resistance from weatherstrip) then like 69 said, window stops. these are physically in the window track itself. If its the weatherstripping being hit, there are adjustments(top of door) which actually work the opposite of the way you would think. Experiment and tinker with till it goes up high enough to keep rain/wind out.
Old 09-30-2012, 12:57 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
FWIW: the assemby instruction manual has a page outlining the door glass adjustment procedures used on the assembly line.
Old 09-30-2012, 01:23 PM
lvmyvt76
lvmyvt76's Avatar
since it is not the window stops, did you clean and lube everything??
Old 09-30-2012, 02:36 PM
Doug1
Doug1's Avatar
how do you know its not the stops? was there a post and then it got deleted?
Old 10-01-2012, 08:28 AM
MacVette13
MacVette13's Avatar
Just have a look on this tips.http://www.corvettemagazine.com/1969...s-replacement/
Old 10-01-2012, 08:40 AM
lvmyvt76
lvmyvt76's Avatar
he said he could pull them up by hand, so the stops are not stopping them. The motor does not pull it up the rest of the way, so either a weak motor or dirty parts stopping it from finishing it journey. Are you trying to raise the window with the door open or closed? If it goes up with the door open, then an adjustment problem could be the cause.
Old 10-01-2012, 09:36 AM
Doug1
Doug1's Avatar
oh yeah, i didn't see that. no different then my wife saying i don't listen to her
Old 10-01-2012, 04:27 PM
Doug1
Doug1's Avatar
"corvette 1982" must have fixed his window problem, his post that started this thread is/was his only one. haven't heard from since....
if it is fixed from one or a combination of some of the responses he got, a thank you is always nice. I gotta say the generosity of guys's time and knowledge on this board is board is second to none.
To window adjustment
Quick Reply: window adjustment
