Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-31-2002, 05:18 PM   #1
chigung
Junior Member
Default Crack in my frame! Bad frame? Is my car scrap? large pics
is my car toast? I wont embarass myself by telling you how much i paid.
Crack pic 1 (drivers side)
Click the image to open in full size.
Crack pic 2
Cross member (under gas tank)
Drivers side nose thingy
Drivers side nose thingy pic 2
Passenger side nose thingy
Rear cross member drivers side
Rear cross member passenger
My 78
My78 rear
[Modified by chigung, 9:43 PM 5/31/2002] [IMG][/IMG]
[Modified by chigung, 10:34 PM 5/31/2002]
chigung is offline   Reply With Quote
Old 05-31-2002, 05:19 PM   #2
chigung
Junior Member
Default Re: Crack in my frame! Bad frame? Is my car scrap? large pics (chigung)
you guys think that crack can be repaired?
Old 05-31-2002, 05:30 PM   #3
PrarieShark
CF Senior Member
PrarieShark's Avatar
Location: The cure for the blues is eight cylinders roaring
I would think that they should be able to weld the crack and reinforce it with a patch.It looks like its time to do a frame off work. :smash:
PrarieShark is offline   Reply With Quote
Old 05-31-2002, 05:31 PM   #4
Mike69@ECS
Premium Supporting Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Mike69@ECS's Avatar
Send a message via AIM to Mike69@ECS
Maybe its me but I cant really make out any cracks... ok in picture 1 and 2 I see the lines, but it dosent appear that any section is cracked through the frame. In fact I think they kind look like seams.
the last couple of pics certianly show some rust but again I really dont see any cracks.
Then again in many of the shots I can't even tell what part of the frame Ii'm looking at! Are some upsidedown???
If you have any concern though I would take the car to a frame shop to have checked out!!! :cheers:
EDIT____ OK Pics 2 looks like a crack but again it dosent appear to go all the way through does it???
[Modified by Mike69, 4:33 PM 5/31/2002]
Mike69@ECS is offline   Reply With Quote
Old 05-31-2002, 05:36 PM   #5
chigung
Junior Member
yea, the crack does go all the way through.
sorr about the confusion with the pics
Old 05-31-2002, 05:43 PM   #6
03whitecoupe
CF Senior Member
03whitecoupe's Avatar
You can get a replacement frame for around $1500 used. I had similar problem with mine, bought a good solid used frame had it chemically dipped and POR 15 painted and it's as good as new. It's not cheap and very labor intensive but can be done. Beats the alternative of getting rid of the car. Good luck!
03whitecoupe is offline   Reply With Quote
Old 05-31-2002, 05:45 PM   #7
chigung
Junior Member
there, fixed the pics!
Old 05-31-2002, 05:49 PM   #8
The_Dude
CF Senior Member
St. Jude Donor '11
The_Dude's Avatar
I don't have any experience with frame problems, but it seems to me that there are shops that can fix things like this. From your pictures, it didn't look like you had terrible rust. Entire frames are also available if yours is toast. Good luck.
The_Dude is online now   Reply With Quote
Old 05-31-2002, 05:50 PM   #9
Matt Gruber
CF Senior Member
as you learned, you crawl under it before you buy it,
do you have the place to pull the body off and replace the frame?
When i got my 1st c1 in 1975 i made a mistake, so i sold it "as is". life is a learning process.
i guess you are saving the "best" for last? the area ahead of the rear wheel rusts out first.
good luck :eek:
Matt Gruber is offline   Reply With Quote
Old 05-31-2002, 05:50 PM   #10
JB
CF Senior Member
St. Jude Contributor
JB's Avatar
Default Re: Crack in my frame! Bad frame? Is my car scrap? large pics (Mike69)
Don't panic, easy & fairly cheap fix (maybe a few hundred bucks, tops). I had cracks just exactly like those around your springs on my '78. Several of the other forum members have had this problem in that exact same place too & will no doubt chime in soon. You just need to get it welded up, preferably by a shop that knows something about vettes, but at least by one that does frame repairs. I saw pics from one guy a few months back where he'd gone over a speed bump funny and tore part of the suspension loose along there. He got someone to jack it up and weld it, no problems.
However, I'd probably stop driving it until you get that done. Could be ugly if something let go.
JB
[Modified by JB, 3:58 PM 5/31/2002]
JB is offline   Reply With Quote
Old 05-31-2002, 06:35 PM   #11
chigung
Junior Member
thanks for all of the good tips.
If you have any other suggestions, let me know
dave
Old 05-31-2002, 07:22 PM   #12
45ACP
CF Senior Member
Easy fix.
You just need to find a pal who is a fabricator/welder or a shop that does this kind of work routinely. In the hands of the right guy, the repairs will likely end up stronger than original and have a very professional look to them - unlike the repair work shown in a couple of the pictures.
45ACP is offline   Reply With Quote
Old 05-31-2002, 07:26 PM   #13
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Default Re: Crack in my frame! Bad frame? Is my car scrap? large pics (45ACP)
Easy fixes couple hundred bucks :D
MotorHead is offline   Reply With Quote
Old 06-01-2002, 02:31 AM   #14
chigung
Junior Member
Thanks again guys, i feel better!
Old 06-01-2002, 06:34 AM   #15
Twin_Turbo
CF Senior Member
Aaron74 is the one who tore out his suspension on a speedbump :)
I think it was more than a couple of 100$ to fix.. ask him or Ken73.
Marck
Twin_Turbo is offline   Reply With Quote
Old 06-01-2002, 07:37 AM   #16
Chuck Gongloff
CF Senior Member
Support Corvetteforum!
Chuck Gongloff's Avatar
Looks like serious, major problems to me. I would get under the car with a pick or a phillips screw driver....especially in the area of the front of the rear wheels and the crossmember and start hammering. See how thin the metal is, and see how big the holes are when you start pounding on them. Chuck
Chuck Gongloff is offline   Reply With Quote
Old 06-01-2002, 08:14 AM   #17
chigung
Junior Member
Default Re: Crack in my frame! Bad frame? Is my car scrap? large pics (Chuck Gongloff)
What will that accomplish?
Old 06-01-2002, 08:37 AM   #18
Chuck Gongloff
CF Senior Member
Frame rust is like looking at the tip of an iceberg. If you start pounding and picking, around the visible holes and cracks, you'll open up usually a much larger area. What appears to be a "rust through" pin hole opens up into a 1 or 2 square inch hole. Usually where there is rust through, the frame, inside is also rusted and paper thin. On the rear crossmember pictures, it looks like it's already separated from the main frame. Check the area where the trailing arms mount. Check under both the right and left doors in the rear, and also check the kick up area....inside of the trailing arms where the frame turns upward around the rear wheels. Start "picking and tapping" and let us know what you find. That frame does not look like a "dry Texas" frame. Looks like a frame from a car driven where they use a lot of salt on the roads. I don't mean to upset you....I'm trying to be helpful, but if your frame is literally rusted in half, or if the crossmember is already separated from the main frame, you've got some serious problems, likely far beyond the re-weld and patch solutions. Chuck
Old 06-01-2002, 09:23 AM   #19
chigung
Junior Member
well, i took a hammer and a center punch and started ponding away at the points that you suggested. It seems that there is some kind of black paint that coats the frame.
I pounded the heck out of about 20 points on the frame, and got no deterioration. the cross member that has the bolts in it is rusty, and isnt bolted to the frame snug, but the main frame that it bolts to appears to be ok. I pounded the crazy wend job done to the "front nose thingy" to allow access to the bolt, no give at all.
I about to sent my t-arms to bairs to have rebuilt (bearing is going out), unless you guys think that this is serious enogh that i should put that off, and have her towed to a frame shop first. I really dont want to drop a lot of money on a car that isnt safe to drive. She drives very straight, if that means anything. The T-arms look good, i pounded the heck out of them as well, no give at all.
Old 06-01-2002, 09:25 AM   #20
gq82
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
gq82's Avatar
Listen to Chuck, he knows what he's talking about. A frame that appears to be in the condition yours is in is a dangerous thing. Have a professional check it out.
gq82 is offline   Reply With Quote
Reload this Page Crack in my frame! Bad frame? Is my car scrap? large pics
Tags
1982, a, bad, buy, car, cars, control, corvette, crack, cracked, cracks, frame, pics, scrap, talking
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How well do C4's age? Paul_C C4 General Discussion 15 06-02-2003 03:18 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
