Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-11-2012, 09:13 AM   #1
C3Paul
CF Senior Member
C3Paul's Avatar
Default Correct spark plug heat range for 383 with Aluminum heads?
I have been searching CF and internet to find out the correct spark plug heat range for my engine, but not having much luck.
My engine is 383ci with 10:1CR and aluminium heads and almost stock HEI with upgraded high voltage chip.http://www.ecklerscorvette.com/corve...1975-1980.html
I have bought these spark plugs but am not sure if the heat range 4 is little too hot?
http://www.ngk.com/more_info.asp?AAIA=&pid=2656
NGK heat range goes from 10(cold) to 1 (hot)
What heat range would you recommend for the initial starting point?
I would like to stay with NGK product as it is easily accessible in the UK
C3Paul is offline   Reply With Quote
Old 08-11-2012, 10:42 AM   #2
capevettes
CF Senior Member
capevettes's Avatar
I have been using NGK UR4 plugs in my 383 in my 61 for many years. Runs great. It is 10.25:1 compression, 202/160 iron heads.
capevettes is offline   Reply With Quote
Old 08-11-2012, 01:42 PM   #3
Ironcross
CF Senior Member
Ironcross's Avatar
The same heat range used before the change
Ironcross is offline   Reply With Quote
Old 08-11-2012, 02:32 PM   #4
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
I have been using the same spark plug for years with aluminum heads that is NGK V-Power BKR6E it is medium cold and I never had a problem with them on a 550HP and now 600HP small block, they are 3 bucks each
V-Power Resistor Spark Plug
14mm x 3/4" Reach
5/8" Hex
ISO projected
Gasket seat
http://www.ngk.com/results_cross.asp...on.y=12&mfid=1
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage......................................My'70 CUDALotsa ladies and lotsa trouble
MotorHead is offline   Reply With Quote
Old 08-12-2012, 01:08 PM   #5
C3 Stroker
CF Senior Member
C3 Stroker's Avatar
On my previous 383 with AFR 195 heads, and also with Trick Flows, I used AC Delco FR3LS's which were recommended by both companies. The current number for these is AC #41-629. These worked out perfectly for me.
For NGK and other brands, cross refence with this link:
http://www.sparkplug-crossreference....DELCO/FR3LS%20
C3 Stroker is offline   Reply With Quote
Old 08-12-2012, 05:34 PM   #6
MotorHead
CF Senior Member
MotorHead's Avatar
Pretty much the same as I run, as the cross-reference calls for NGK BKR6ES and says:
"A cheaper alternative are NGK BKR6E plugs, but they won't last as long."
So maybe you will only get 50,000 miles on them
Old 08-12-2012, 05:43 PM   #7
MotorHead
CF Senior Member
MotorHead's Avatar
Quote:
That is a tapered seat plug, he might be looking for gasket seat plug, you have to be careful in this regard
Reload this Page Correct spark plug heat range for 383 with Aluminum heads?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Spark Plug Gap Question cumbercr C4 Tech/Performance 6 01-26-2014 01:19 AM
spark plug heat range 75sl48 C3 Tech/Performance 2 12-12-2013 05:56 PM
What heat range spark plugs are you running? adamgl C6 Z06 Discussion 6 05-03-2013 03:40 PM
MSD 8.5mm and NGK Spark plugs. Best price anywhere 99blancoss C5 Tech 375 12-27-2012 10:33 AM
FS - Brisk Racing Spark Plugs ltborg C5 Parts for Sale/Wanted 8 11-08-2012 08:32 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
