'82 Power Seat & Window Issues
When I first purchased my 82 vette, the control panel that attaches at the bottom of the drivers seat kept coming off. Seat able to be adjusted then one day... no more. Drivable but I am having to keep a small pillow behind the seat back to allow me better control.
I am thinking perhaps a broken loose wire but not much room to get to without having to completely remove the seat (pain). Is there any way to bypass enough to get seat set? Don't need to move up much, but anything would be good.
Also, passenger window switch in middle console keeps falling down into the whole to where switch no longer works. I have shimmed it up from below once before, but this seems only a temp fix. Any suggestions?
Check and see if you have power going to the seat. There's a two wire plug under the seat you can unplug. Unbolt the seat if you have too. The seat switches were used on Cadillacs and other luxury cars and it will be a fuse or circuit breaker type fuse powering everything.
Can I take you up on the pictures offer? I would be much obliged for it help my confidence in taking on projects I know I can do myself. On the window switch issue, how do you get the switch to stay up and snug in the console plate? Alot of space between switch base & frame. Any suggestions?
PhotoBucket Link of 82' Restoration
Copy and paste the link in your browzer
http://s1087.photobucket.com/albums/...on18z/?start=0
the problem that i have found with the power seat is the wires go bad because you are sitting on them .check the wire from the connection to the switch .
More likely the problem lies within the 6-way switch on the driver's seat. More times than not, if you remove the switch and take it apart and clean the contacts and wire connections it will be operational (provided nothing is broken or missing). Thirty year old cars have a tendency to accumulate dirt, grease and corrosion, all of which play havoc on both electrical and mechanical systems.
1982 electric seat
when i bought my 82 2 months ago the power seat would not work.
i took it to the shop they said all it was the ground.
apparently they cleaned where it grounds and that was it.
I do not. However I do have some parts for an '82 like original rear bumper cover (I changed style during my restoration), original rear tail light/back-up light assembly (Went to bubble lenses), and air scoop flapper & solenoid (removed from my car for direct air intake), and parking brake console cover. If interested, I will send pictures and price.
Removing the seat is very easy, Four nuts under the car lift the seat unplug the wire connectors and lift it out. Once out you can unbolt the seat from the adjuster and then put it on the bench to work on it.
My 81 had bad brushes in one of the motors. disassembling the motor to repair it is easy but putting it back together is impossible.
I bought another Power seat rack on ebay for $175.00 and solved the problem.
