Block off heater hose ?
#41
BILL
#43
Instead of cutting in gas/water valves or ripping out/capping heater hoses if you were to get the Chassis Service Manual for your year corvette you would see how your HVAC system works and be able to R&R it instead of using in my opinion Bubba fixes.
The figure below is from the Service Manual for my car a 1971. As you can see there are a number of doors that direct heated or outside air through the cabin. The Temp Door which is controlled by the temp thumb wheel on my car opens and closes via a Bowden cable. In a lot of cases the cable binds/disconnects causing the door to remain open allowing heated air into the cabin. Also the seals around this door deteriorate over time. Fix this and your car will feel the way it did when it was driven off the showroom floor......mine does.
The 5/8" return heater-hose had some grooves in the outer surface from rubbing on the A/C pulley; I cut out the damaged section and replaced it with a shutoff valve for 3/4" pex hose (it fit the return hose perfectly), and the cabin is cool again. I'll fix it all right when I convert to Vintage Air...
#44
I don't know if this is actually going to work but I decided to give it a try. I bought a heater bypass valve for my big block '72. It's for a '93 Chevy Astro van. It's vacuum actuated and bypasses the heater core while allowing coolant to circulate through the expansion tank, just like it was designed to do. There may be some back eddies letting hot coolant get to the heater core so it may not be as effective as two shutoff valves. On the plus side I should be able to switch the heat on from inside the car. I usually need the heat during Florida's torrential downpours to mix with the A/C to keep the windshield clear. To activate/deactivate the valve I plan to connect it to the manual wiper door valve below the steering column. I changed to a long L-88 hood so there is no need for that valve.
#45
I have a new vacuum operated shut-off valve, but since I put in my 383, the engine does not produce enough vacuum to operated the heater/ac vacuum controls. I had to add a vacuum pump to operate my brakes and it takes a couple minutes for my headlights to rise (working on changing headlights to electric). The manual shut-off valves made a huge difference for me.
#46
Why cant a simple hose be run from the water pump to the intake ??
#47
That's the way our '77 was when we got it. Worked fine, but I plugged off the fitting spots on the intake and water pump instead of having a loop of heater hose hanging there. Cleaner looking IMO.
Adam
Adam
Neck (06-28-2023)
#48
#50
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The assembly manual for my '71 shows a factory vacuum-actuated hot-water shutoff valve as part of the small-block A/C setup; there is no sign that the A/C on my '71 ever incorporated such a valve.
Thats how mine works.
#53
#54
68's without AC do not have cut off values ... I don't know what they were thinking. I have added a ball valve but haven't been able to test it out since my car isn't put back together yet. I also repaired/restored/cleaned the entire vent system to include the doors and seals. Can't wait to get the front clip back on and go for that first drive.
A well sorted out HVAC system in a C3 should allow for a comfortable temp in the cabin without the need for home made valve installs. I never use the AC in my car. I test it in the spring, mid-summer and b4 storage. I drive in any weather in comfort without hot air coming in thru the heater outlets.
#55
I installed a PEX shutoff valve on my heater core line (the one coming off the intake) and had issues with the car overheating when it was blocked off. Open the valve, and all is good again. That was with a stock water pump. Now I have an Eldelbrock victor water pump and it still does the same thing! How is everyone else blocking this hose without this issue?
Temp sensor is in the passenger side head, Temp gauge is a tested accurate autometer. My car will stay cool (180*) sitting in traffic on the sun with the valve open. I closed the valve the other night to test it again and it started to get hot (220*) within minutes.
The heater core is not cooling my car 30*+. I have some kind of circulation issue that no one else has
#56
That's precisely why I installed a valve in the heater core line in my C5. It makes a noticeable difference in cabin temps and the performance of the AC. On my C3 I just put brass plugs in the water pump because it's strictly a fair-weather vehicle anyway.
