Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-21-2012, 05:10 PM   #1
erieaddict
CF Member
Default Timing mark out 180 degrees
First of all, i have been lurking here for about 3 weeks learning about my 1978 corvette that i am just getting back out on the road after painting the body and redoing the interior for the last year.
This is a great resource and i thank the admin folks for a terrific site.
In reading this site i decided to move ahead with a timing advance curve kit. I purchased, cap, rotor, wires, coil, plugs and advanced kit. I figured i would check the timing, vacuum and idle before tearing into it.
My car is a l48 350 auto, pretty much all stock except for headers and a true dual exhaust. i did have my carb rejetted do to the new exhaust. the car starts, runs smoothly at all rpms and also starts fine warm, no pinging.
Back to the issue, when i took a reading of the timing with the vacuum disconnected and plugged at the advance can, i could not see the timing mark. i shut her down, rotated the crank and cleaned off the timing mark and put a dab of yellow paint on the groove. Started the engine back up and still couldn't see the timing mark. if i move the timing gun over to the right side of the motor, i can see the timing mark. It is like it is out by 180 degrees. i am sure i have the inducter on spark plug #1, the first plug on the left side, what could i be missing to get my tinming mark back to the timing tag? Thanks in advance!
erieaddict is offline   Reply With Quote
Old 06-21-2012, 06:52 PM   #2
TimAT
CF Senior Member
TimAT's Avatar
Pull the #1 plug, (left front as you stated) remove the distributor cap and have a helper bump the engine over. Confirm that the timing mark(s) line up when you a sure you're at #1 firing position.
TimAT is offline   Reply With Quote
Old 06-21-2012, 07:39 PM   #3
Mooser
CF Senior Member
Support Corvetteforum!
Mooser's Avatar
Well if it was somehow out 180 deg, you would have to go under the car over on the pass-side to see it.
If it runs smooth, it can't be out that much unless the harmonic balancer has separated and spun.
Couple of questions, don't take it the wrong way.
1.. your down on the #1 plug (front driver side) and not up in the wires somewhere that might have gotten mixed up by accident
2.. Are you checking it at idle speed (under a 1000 lets say)
3.. your not using a dial-back timing light that is set to something other than zero
Mooser
Mooser is offline   Reply With Quote
Old 06-21-2012, 08:12 PM   #4
Jeff_Keryk
CF Senior Member
Jeff_Keryk's Avatar
Perhaps your timing mark is ok, your plug wires are 180* out.
Jeff_Keryk is offline   Reply With Quote
Old 06-21-2012, 08:17 PM   #5
erieaddict
CF Member
mooser, not taken the wrong way at all. any guidance is appreciated
1.. your down on the #1 plug (front driver side) and not up in the wires somewhere that might have gotten mixed up by accident?
I have my timing light pick up down by the plug boot on number 1
Idle speed is at 850 and drops about 100 rpms when i disconnect the vacuum
No, i have a craftsman regular old timing light with no dial on it.
Jeff, interesting, how would my wires get 180 out of time? Would the engine still run?
Old 06-21-2012, 08:43 PM   #6
oldalaskaman
CF Senior Member
oldalaskaman's Avatar
whoever installed your dizzy, started #1 wherever the rotor pointed to, reset the dizzy, rewire per small block spec's
the other option, your harmonic ballancer ring has splipped
oldalaskaman is offline   Reply With Quote
Old 06-21-2012, 09:09 PM   #7
mds3013
CF Senior Member
mds3013's Avatar
Do you have the inducter right at the #1 plug with the arrow pointed towards the plug? Assuming it has an arrow. If you have it at the front drivers side plug you are on #1. Incorrectly installed dist. with wires adjusted for that condition would not change where the timing mark shows up. I am thinking slipped outer ring on balancer. I may not be thinking correctly however. It has been a long day. Mooser's idea about set back timing light not set to zero could cause it also. Good luck with it. mike...
mds3013 is offline   Reply With Quote
Old 06-21-2012, 09:11 PM   #8
Mooser
CF Senior Member
Mooser's Avatar
I don't want to think about this but that line has to line up with tdc #1 regardless of where the dizzy is and the spark has to hit at #1, even if the dizzy is out any number of stations, it still needs to fire #1 at TDC (well you know, around tdc) so that shouldn't matter.
I'm going to have to say unless someone did something bizarre with the cam-gear, it pretty much has to be the balancer has spun
Mooser
Mike hit save before my brain started.
Do like TimAT said and bring #1 up to tdc (put your finger on the hole make sure it's pushing air out so you know it's not the exhaust stroke) and see where the mark is. To be dead sure, you'll need to pull the valve cover and watch the rockers.
Mooser
Old 06-21-2012, 09:16 PM   #9
my 76 ray
CF Senior Member
my 76 ray's Avatar
Quote:
I respectfully disagree. If someone did that, it would still be firing when number 1 is approaching TDC. I do agree with the slipped balancer theory. I would find true TDC and see where the mark is then.
my 76 ray is offline   Reply With Quote
Old 06-21-2012, 09:30 PM   #10
scottyp99
CF Senior Member
scottyp99's Avatar
You can always make a new mark, once you find top dead center on the compression stroke for cyl. # 1, but if the dampener has slipped, who's to say it's not going to keep moving around? If it's a slipping dampener, the only fix is a new dampener. Or JB Weld.
Keep the shiny side up!
Scott
scottyp99 is online now   Reply With Quote
Old 06-21-2012, 09:30 PM   #11
oldalaskaman
CF Senior Member
Quote:
ya know yer right, I brain farted
Old 06-21-2012, 10:40 PM   #12
Jeff_Keryk
CF Senior Member
Jeff_Keryk's Avatar
I was thinking your timing light lead might not be on #1 cylinder. But if it is, I would have to guess your dampner is shot.
Old 06-22-2012, 03:57 AM   #13
aussiejohn
CF Senior Member
aussiejohn's Avatar
Default Timing out by 180????
Just a thought, as the timing is out by 180 degrees, could this be caused by having the camshaft installed 180 degrees out? In other words, the timing mark on the cam was exactly opposite from where it should be, relative to the mark on the crankshaft.
I'm probably wrong, but could this account for the timing mark to be so far out?
Regards from Down Under.
aussiejohn
aussiejohn is offline   Reply With Quote
Old 06-22-2012, 04:26 AM   #14
7T1vette
CF Senior Member
7T1vette's Avatar
Exactly correct. It's about the only way you can get a SBC engine to run well with the timing mark 180 degrees off-position. Someone has mis-indexed the alignment marks on the timing gears.
7T1vette is offline   Reply With Quote
Old 06-22-2012, 07:42 AM   #15
markdonc
Junior Member
markdonc's Avatar
There is no such thing as putting the cam in 180 degrees off. Since the crank turns 2x for every turn of the cam, if you turn the crank 1 full revolution & allign the timing marks everything except maybe the distributor should be where you eant them.
markdonc is offline   Reply With Quote
Old 06-22-2012, 09:17 AM   #16
larrywalk
CF Senior Member
larrywalk's Avatar
Slipped balancer ring?... Check to see that the TDC mark aligns with the keyway slot of the hub (pre ~69, or 10 deg CCW after). As a rough check, the pulley bolt on one of the 3 arms of the hub also should be aligned with the keyway slot.
larrywalk is online now   Reply With Quote
Old 06-22-2012, 09:30 AM   #17
wombvette
CF Senior Member
wombvette's Avatar
Quote:
Yep, Most common with these engines.
wombvette is offline   Reply With Quote
Old 06-22-2012, 09:39 AM   #18
74Ken
CF Senior Member
74Ken's Avatar
Location: North Oshawa (where all the Camaro's are made) Ontario
The other thing I would suggest is try another timing light, just in case that one is defective. You could be panicing over something that really isn't there.
Borrow a friends light and check to see if his light reads the same way.
Ken
74Ken is offline   Reply With Quote
Old 06-22-2012, 10:36 AM   #19
Mike Ward
CF Senior Member
Mike Ward's Avatar
Location: about an hour away from Paul74 in Ontariariario
Quote:
Care to think about that one for a while?
Mike Ward is online now   Reply With Quote
Old 06-22-2012, 11:53 AM   #20
7T1vette
CF Senior Member
7T1vette's Avatar
Whatever you think, Mr. Wizard...
Reload this Page Timing mark out 180 degrees
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
