unique tach issue
Old 04-25-2016, 07:16 PM
rhino33
3rd Gear
rhino33's Avatar
Default unique tach issue
hi; I have a 1980 vette that i have installed a 2012 ZZ4 crate engine and the tach filter stopped working after the car was driven hard, i have subsequently burned up another filter and 2 boards. the second filter shorted to ground and overheated my module thus no spark, when unplugged from the tach output the car started and ran fine.
i then ran direct which worked fine for a while and eventually stopped working
I think that this new distributer 2012 has too high current
perhaps a simple ballast resistor in line with a new filter or possibly building a more robust filter
any advice would be greatly appreciated
thanks
Old 04-25-2016, 08:57 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
thanks
Unless the distributor/coil is defective... they all put out the same square signal and should not be an issue. What brand is the distributor? Something is spiking your boards but what I have no clue.
Old 04-26-2016, 06:10 AM
rhino33
3rd Gear
rhino33's Avatar
the distributer is from GM that came with the ZZ4 turnkey package.
last time I installed the new filter and board all was well at start up then after a bit of hard acceleration the filter failed.
I wish I could learn why before I replace the filter and board once again
Old 04-26-2016, 11:23 AM
0Willcox Corvette
Former Vendor
You'll need to figure out what is spiking the board for sure. Let me talk with Bobby here and see if he has any suggestions. I won't see him for a couple of days but email me at Support@Willcoxcorvette.com and I'll see what I can do for you.
Bypass the filter and see if the board is still working. If it's our board, it's fused and an easy fix... 14.00 plus shipping.
Old 04-27-2016, 06:10 AM
rhino33
3rd Gear
rhino33's Avatar
email sent thanks
To unique tach issue
Quick Reply: unique tach issue
