Champion Radiator - C3 factory brackets don't look right - see pics
As part of the restoration on my C3 the factory radiator was replaced with a champion radiator. It fits into the space as it should but the top is not rounded off like the factory radiator and the upper mounts don't secure it firmly in place. The radiator appears to be loose. I didn't replace the factory foam that surrounds the radiator as it shows in the book and the car didn't come with any foam with the old radiator.
Is there an upper mount used for a champion radiator thats different than factory? The Champion radiator has a 1 1/2" rib running across the top.
Click on the link and you'll see the pictures of what I'm talking about.
http://pix.kg/p/574043873507%3A567024824/sct
Thoughts?
Mike
Thoughts?
Mike
I got some heater hose , the appropriate size, and slid it over the mounts , upper and lower, till I can hunt down some nice thick foam. not perfect but for temp. it works. if you split the hose it will conform to the mount better
What model radiator did you buy? I just bought a Champion and it looks different than yours(see pic). I did have a similar problem though. I used a new razor knife and customized the mounting rubbers and it made the fit better but not perfect. With everything hooked up it fits tight.
What are you guys using for lower a lower pad thats mounted between the lower radiator and support?
Mike
Mike
Iggy - I realize this is the bottom but it looks exactly the same on top. I can post a pic if I need to. This one was already in the laptop. Mine is a 4 core. Maybe that is the difference.
bought a genisis for my C4 that looks like yours, they probably changed versions in the production sometime.
I bought a new Champion 4 row aluminum radiator from a reseller on fleabay. My car's frame horns needed to be notched for clearance and the OEM upper radiator mounts did not come close to fitting. Top mounting brackets had to be custom fabricated from aluminum and the stock rubber cushions did not work, top or bottom. New cushions were bough from Jegs and needed to be ground out to conform to the Champion radiator with a stone in a drill. After mounting, I discovered the hood did not close because the square corner of the radiator driver side hit the underside of the stock hood. The fiberglass needed to be ground out for clearance and then glassed over. So much for an advertised direct fit radiator by Champion. It appears your radiator is smaller and not with all the same problems I encountered. My radiator look similar to Iggycat's radiator, but apparently larger.
Also, I planned on cooling my trans with the radiator, but the trans line bungs were a female 3/8ths inverted flair carburetor thread, but seemed to be metric. I couldn't find any AN or otherwise fitting to fit the bung and make a seal, so I needed to mount a separate cooler for the trans. The instillation of the radiator took me longer than any other project on the car, and everything has been redone. Half way through, the additional cost of a real direct fit radiator started to look real cheap!
Location: Where it's always hot as Hell-South Louisiana.
1 Post
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
O'Reillys sold me a new direct replacement for my 80 model. Made in Mexico. 1 year warranty. Direct bolt in, no issues at all. $175 out the door.Been 16 months, still looks and works fine.
Mike
I have a manual trans so I won't have the deal with the cooling issues.
I'm going to purchase 1/8" rubber for the lower portion of the radiator mount and glue it to the lower radiator support. It's should cushion the radiator well and keep it from sliding around. I'll purchase foam and cut to fit the sides of the radiator/shroud and replicate the factory look for a tight seal. Thanks for the information.
Mike
if you insert it at an angle, that corner first, you dont have to grind.
Thanks..
Mike
Thanks for all the help guys. Almost completed a frame-on restoration of my 76 C3 and it's starting to take shape. Restored everything on the car from front to rear over the last two years and it's certainly not the same car that pulled in my garage prior to tear down... I want to get the engine started and the radiator issues are holding things up. More to follow.
Great website, great feedback..
Much appreciated,
Mike
Much appreciated,
Mike
