Cracked fiberglass front bumper on my '74 convertible - repair or replace?
Old 06-11-2012, 01:16 AM
brian717
Cruising
brian717's Avatar
Default Cracked fiberglass front bumper on my '74 convertible - repair or replace?
So, my front bumper is chipped and cracked. I'm trying to figure out what would be cheaper - replacing it or repairing it.
I have found a TruFlex replacement online for about $300, but I understand that between fitting and painting it, the body work can still get expensive. Would it make more sense to just see if a body shop can repair it?
I'd appreciate any advice I can get. Pic of the damage is below (couldn't get the image embedding to work, had to link to it):
http://sdrv.ms/Ofb5X8
Last edited by brian717; 06-11-2012 at 01:24 AM. Reason: Trying to get the link to the image to work...
Old 06-11-2012, 02:23 AM
mrmagrath
mrmagrath's Avatar
It's fibreglass. Have a go at repairing it. Research what resin to use with that brand of bumper first. As Rob Schneider says in Adam Sandler movies, "You can do it!" Plenty of how to guides online and help on the forum.
Old 06-11-2012, 04:31 AM
tfi racing
tfi racing's Avatar
Relatively easy fix,go for it!Some basic fiberglass repair kit,filler,high solid spray can primer,and paint the bumper.Give it a try,the worse that can happen is you have to buy a new cover and give it to the pro's.
Of course,by this time tomorrow,you will get more than one reply that nothing short of a body off restoration will properly fix that,your frame is surely bent and the car is obviously unfit and unsafe to drive until then...
To Cracked fiberglass front bumper on my '74 convertible - repair or replace?
Quick Reply: Cracked fiberglass front bumper on my '74 convertible - repair or replace?
