Weatherstrip / Hardtop
I am about to change the weatherstripping of my 1971 Hardtop so that I can use the hardtop on the car without ruining the paint (the old weather strips are original and worn out).
Any advice or tip on how to do that? Do I need any particular kind of tool? Is it pretty straightdforward or rather tricky?
Any piece of advice is welcome.
Thank you.
Thank you.
I did this job over the past winter without ANY issues. Take your time, removing the old weather stripping and then clean well as has been already suggested here. I think I used pliers and a small screwdriver, however, as I recall, tools were more of a convenience than a neccessity. Use 3M weather stripping adhesive to install new stripping. (I got my new stripping from Paragon- fit very well). Apply the adhesive to both surfaces (top and rubber). Allow the adhesive to "tack" before assembling. Be careful when assembling. It's tough to re-locate if you don't get proper location on first attempt. In fact, it might be a good idea to "dry fit" BEFORE you apply the adhesive.
Good luck with your project. I hope this helps!
Received 1,470 Likes
Cruise-In II Veteran
Purchase the assembly instruction manual (AIM). It shows the factory installation of the weatherstripping.
Even with new weatherstripping, a deck lid protector is not a bad idea. I have a clear one on my 68. Visible, but not particularly distracting.
The weather stripping is glued and screwed. Your old screws and the special washers that hold the weather strip in place are likely deteriorated. You may want to consider getting new screws and washers. Dr. Rebuild sells a kit.
Are there diagrams/step by step directions with pictures describing weather seal removal? Has anyone had to drill out broken/stripped screws from the rear plate that secures the t-tops? Can you remove the backing plate and reinstall?
"AIM" = Assembly Instruction Manual. If you don't have one, you're missing one of your best, and certainly most used tools in the tool box.
The AIM will show exploded view for the top, including weatherstripping. No specific instructions for disassembly since it's an Assembly Manual. It will clearly show how the top's components look and go together.
Agree completely with the deck lid protector. Order this when you order the weatherstripping. I was able to install my (clear) protector so that it is tucked inside so much, it's almost un-detectible.
While you have the top apart for weatherstrip replacement, it would also be a good time to remove the stainless perimeter trim and polish it up. Unless it's real bad, I would just polish the rear glass stainless trim on the top. Bad things can happen if not very careful back there...
