69 Roadster Headlamp Warning Light
Cruising
Just wondering when the headlamp warning light in the dash should be on, should it be on when the headlamps are turned on or do I have something wired up wrong?? It;s the red light where the door ajar light is in the centre console above the gauges.. Cheers..
When they are fully up or down, it should be off.
Roadsters don't have rollup windows......
there is a limit switch that is pushed in when the headlight is fully open, in most cases they are broke, there just plastic
Cruising
Cruising
OK I found the problem, The plugs are there for the switch but there are no switches fitted to the headlamps Oh well looks like another part I will need to order, atleast I know how to fix them now..
Cheers..
Cheers..
