Get my L48 to 350 horsepower.
Old 06-08-2012, 07:23 AM
  #41
resdoggie
Had a 1976 L-82, 4-sp
Support Corvetteforum!
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
I just put on 100 miles with my new AFR 195's, Team G 7530 SP intake and Holley Street HP 650 DP. Cam is CC Magnum 280 FT. WOW!!!! The car literally throws me back in the seat like never before! Car is running great with the Team G. There are other options other than Edelbrock intakes that work just fine. Btw, glad I popped the extra few hundred bucks for the AFR's. Great piece of workmanship.
Old 06-27-2012, 06:37 PM
  #42
bobward1226
4th Gear
bobward1226's Avatar
Default more horsepower without a new cam?
I have a 71 with a original 350 i already put a new exhaust with new headers I'm getting ready to put a holley mechanical carb new intake and hei distributor but was told not to put a cam because of the motor having 85k on it any suggestions?
Old 06-27-2012, 08:47 PM
  #43
bluedawg
bluedawg's Avatar
with 85,000 miles I'd atleast do a compression/leak down test on it before sticking a cam in. if the rings arn't in that good of shape you could go through the bottom end and change heads while your at it. if the cylinders pressures are in a decent range, then you could change the cam, possible heads.
Old 06-27-2012, 08:52 PM
  #44
bobward1226
4th Gear
Will i still notice an increase in power without the cam?
Old 06-27-2012, 09:34 PM
  #45
bluedawg
bluedawg's Avatar
there will be some gains with the intake, how much is noticeable I wouldn't figure alot. matching the cam to the compression ratio, rear gear and stall converter would be a noticeable difference. match that to a new set of good flowing heads and intake even better.
Quick Reply: Get my L48 to 350 horsepower.
