Spal dual fan blowout sale!!!
Former Vendor
We negotiated a truck load price with Spal and can offer you a huge savings on our dual fan kit SP460. Normally priced at $425, we are now offering these fan kits at $325 while supplies last.
If you are thinking of a radiator/fan combo, just pick out your model radiator add both to your shopping cart. We will mount the fans and install the switch for you and ship it as an assembly.
http://www.dewitts.com/pages/product...asp?ProdID=251
Hell yeah!! It just so happens this was my next mod. Great timing, I'll be ordering a set tomorrow.
Received 3,043 Likes
St. Jude Donor '05
Tom do those both come on at the same time?
Whats the amp draw?
cfm rating?
Whats the amp draw?
cfm rating?
Former Vendor
Tom, I'm running a 195* thermostat with my '81. Will the 195/175 switch work properly with this thermostat? Or will I need to get a 210/195 switch? If so, can I order the kit without the switch since you don't seem to carry a 210/195 switch? I don't want to put a lower thermostat in because the Computer controlled carb system works best with the 195* stat.
24 amps both fans plus 25amps max draw from the stereo power amp.Looks like will need an alternator upgrade along with the fans.What's the best option for a bigger alternator with the least install problems?
Former Vendor
Tom, I'm running a 195* thermostat with my '81. Will the 195/175 switch work properly with this thermostat? Or will I need to get a 210/195 switch? If so, can I order the kit without the switch since you don't seem to carry a 210/195 switch? I don't want to put a lower thermostat in because the Computer controlled carb system works best with the 195* stat. Thanks
so what thermostat is recommended with the setup?
Former Vendor
I'd start out with a 180 stat and the 195/175 switch. That typically works but if you have problems with the fans running to much you can switch to the 160. The switches tend to cycle on the higher side (200/180) and if your 180 stat is 180-175 you're good.
I'll probably order it and try the 210/195 switch that Summit sells. If it doesn't work I can get a hypertech chip that works with a lower temp stat.
Former Vendor
That's right, my answer was to the question of what we normally recommend. In your case (wanting to run hotter) I think you have the right idea. You simply need to make sure the thermostat (which controls minimum) will let you get to the switch shut off point.
Former Vendor
Former Vendor
Former Vendor
That's why I posted this:
"If you are thinking of a radiator/fan combo, just pick out your model radiator add both to your shopping cart. We will mount the fans and install the switch for you and ship it as an assembly. "
When you order the rad/fan combo as one part number the sale price does not show up. Christyn should fix it when running the cc but just to make sure, you should send her an email regarding your order.
