exhaust manifod help
Old 05-06-2012, 01:31 AM
mrcarguy
3rd Gear
mrcarguy's Avatar
Default exhaust manifod help
Hi Everyone,
A quick question on the 81 original exhaust manifolds, Is there a aftermarket manifold that would bolt up to the factory exhaust pipes without modifying?
Old 05-07-2012, 02:32 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
These will do what you want. Not as much power gain as long tube headers. Available in 2" or 2 1/2" flange.
http://www.vetteheaders.com/servlet/...rvette+Headers
Old 05-07-2012, 06:48 PM
doctorgene
doctorgene's Avatar
Yes Sir; Your Question, has many answers. How much do you want to spend? What H. P. gain are you looking for? If you have the original Stainless Steel 1981 & 1982 only, G.M. Factory block huger ones now, long tube headers are what is the next change should be. If you have cast iron manifolds & are on a budget, Factory S. S. are the way to gain around 14 H. P. No changes to existing head pipes. Have a great one. Gene
Old 05-07-2012, 10:08 PM
mrcarguy
3rd Gear
mrcarguy's Avatar
63mako and doctorgrene,
Thank you for your help. I was working with the original 81 exhaust manifolds. I wanted to remove the emission pipes (which I did) and have the manifold's ceramic coated. Unfortunately, they have some cracks in them. So I tried to have them welded but they are to thin. I would like more power but I am not able to spend much now. I believe the previous owner removed the original carb.air pump and possibly the distributor. I would like to keep the temperature down under the hood, don't have a bunch of money to spend. I was hoping to find a manifold that would just bolt up to the original pipes and head. The one's that 63mako found are very nice but more then I have to spend. Is there anything else out there that would fit my 81 Vette?
mrcarguy
3rd Gear
mrcarguy's Avatar
Old 05-07-2012, 10:21 PM
terry82
terry82's Avatar
http://www.mcjackscorvettes.com/ i think these pipes are some of the best but they are verry expensive .they will bolt right up.if you want cheaper pipes summit has some long tube ones that are verry resonable.but then you have to get them connected to the rest of the exhaust system.i would stop and think what you want to do with this car .you can do it cheap now and then do it again later or you can do it right this time and be done .i would check e=bay and this forum in the for sale section for factory pipes .
Old 05-07-2012, 10:58 PM
speedreed8
speedreed8's Avatar
here is a cheaper alternative, i used these dormans brand before with good luck.
http://www.oreillyauto.com/site/c/se...make=Chevrolet
Old 05-08-2012, 12:54 AM
terry82
terry82's Avatar
could just be the pic that they are using but i think you want a center dump flange .i would look for a old pair of the ram horns .
Old 05-08-2012, 08:02 AM
speedreed8
speedreed8's Avatar
yea, that looks like the wrong ones, this is the one i used, fits either side.
http://www.oreillyauto.com/site/c/de...2385&ppt=C0022
Old 05-08-2012, 10:32 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
FWIW: the stock 81 and 82 stainless manifolds are some of the best to ever come from GM. They amount to factory short tube headers. I agree with Doctorgene: keep them.
Old 05-08-2012, 01:25 PM
terry82
terry82's Avatar
$112 dollars seems like a bargin.but i would clean them up inside and out then send them out to be ceramic coated.
Old 05-08-2012, 03:35 PM
scottyp99
scottyp99's Avatar
Too thin to weld? I think you probably just need to find a better welder. There are guys out there that can weld an ice cube to a piece of wood. (OK, maybe I'm exaggerating just a little bit.)
Keep the shiny side up!
Scott
Old 05-08-2012, 04:48 PM
billla
billla's Avatar
St. Jude Donor '14
I can't think of anywhere on those manifolds that is "thin"...
To exhaust manifod help
Quick Reply: exhaust manifod help
