You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Hi d,
The engine harness is a pretty easy one.
If the old one is still in place I'd lay the new one roughly in place and unhook, (old), and then hook, (new), the connectors one at a time.
When they're all connected I'd remove the old harness and tuck the new harness in place in the various clips and clamps.
If you don't have the Assembly Instruction Manual you may want to think about buying one. It will show just how the original was run and where the connections are.... and a zillion other things it will be good to know.
Good Luck!
Regards,
Alan
Hi d,
Good Luck!
Regards,
Alan
This is the best advice. Alan always has good practical advice. My old engine harness was disconnected already but I still had it. Between that and the assembly manual I really didn't have any trouble. Once you start you will see that there is not much to it. Now this assumes you bought a good harness. Mine was from Lectric Limited as I was told they were top notch. Seems to be true.
Installed the new Lectric Limited harness today. The old harness had a few minor wires that were broken off and I couldn't tell where they came from. Needless to say the car doesn't start so maybe those wires weren't so "minor" as I thought. I got a color coded wiring diagram so I'm going to try and figure out where they are supposed to go. I'll probably purchase the assembly manual or Dr. Rebuild if I can't figure it out.
i replaced my engine harness with a new one during my restoration and its pretty streight forward. once you lay in the harness its pretty obvious where the wires will connect to. the starter, the horn relay and the firewall connector is where you have to careful. and of course make sure the battery is disconnected before you start.
AIM shows the installation of the stock harness and where everything plugs up. Is your new harness plugged in well with the forward lamp harness on the firewall?
The first wire is a light brown that splits off the main harness right after the wiper motor. Its about 27 inches long. Any idea where this goes? I believe it goes to the ignition switch but have no idea where the entry hole is located?
The next one I can't figure out is a three wire plug, blue, light blue, light brown. It's located on the passenger side about half way between the wiper motor and starter.
If the forward lamp harness connects with engine harness to the fuse box, then yes.
I could be wrong, but this might be the single wire that lays along the top of the intake manifold on the driver side that connects to the solenoid on the carburetor?
Think I have this one figured out for you as well...connects to the solenoid on top of the intake manifold on the passenger side. Take a look at the attached photo on the bottom left side of the photo you will see this harness with the blue and tan wires. Keep in mind this solenoid on my motor is damaged and inoperable, so it might not look exactly like yours.
Thanks for the pics spdrcr29. My stock carburator was shot so I replaced it with an edelbrock carb. It didn't have any of those solenoids attached to the carb or intake manifold as you do. My edelbrock carb has a solenoid with two prongs on the passenger side (enclosed pic). These are the wiring instructions for it, "Black wire (–): To Ground
(Carb Body), Red Wire (+): To Ignition Key Activated 12V Source (NOT coil or alternator)"
So I'm assuming this is not where the three wire clip attaches to?
