Where is the horn Relay?
Old 04-12-2012, 09:40 PM
Fauvette
Fauvette's Avatar
Default Where is the horn Relay?
Hi,
My horn is not working and I would like to do some troubleshooting. Where is the horn relay? I read that it is under the dash on the passenger side -- but can't seem to identify it. Does anyone have a picture?
Thanks for the help!
Old 04-12-2012, 10:22 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
play Gumby and its by the fuse panel where your left foot goes....real PITA to get to it i hope your not a big guy.
Old 04-12-2012, 10:25 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Bog is right! 74-78 mounted here:
Old 04-13-2012, 05:01 PM
Fauvette
Fauvette's Avatar
Thanks -- I will try to go under there and pull it out...
Old 04-13-2012, 11:47 PM
0Willcox Corvette
Former Vendor
Dive.. Dive... Dive... (sorry, I had too)...
Old 04-22-2012, 10:03 AM
Fauvette
Fauvette's Avatar
Hi -- thanks for this -- I ended up swapping out the horn relay. The horns work beautifully -- the only problem is they blow constantly now.
I have the special "Vega" steering wheel in my '76 (I know it ain't pretty but it kind of grows on me and I like to keep it stock). To start troubleshooting I popped off the horn button and checked on the spring mechanism which seems fine.
I saw the blow-up diagram for the '77-'82 steering columns -- but I am not sure if it is different for the '76.
Any advice what to look for before I start taking things apart? Also, my right turn signal cancel does not work -- could this be related?
Thanks!
Old 04-22-2012, 09:27 PM
Ironcross
Ironcross's Avatar
Clark Gable and Bert Lancaster!
Me too....
Old 04-23-2012, 07:35 AM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Your 1976 T&T steering wheel is unique along with the telescope lock and the horn cap. The horn contact parts 2, 3, & 4 are the same between the various years.
Trouble shooting your horn problem should be the same as 1969 through 1975 and 1977 through 1982.
http://jimshea.corvettefaq.com/?p=909#attachments
Papers that are referenced above can be found at www.corvettefaq.com
Jim
Old 11-23-2012, 04:59 AM
nz corvette
nz corvette's Avatar
I also have a problem with my 77 there seems to be power to the horns all the time!!
any suggestions? cheers Dave nz
Old 11-23-2012, 07:49 AM
AirborneSilva
AirborneSilva's Avatar
Dave/OP, I had an issue with my horn as well, turned out it was part #7 in Jim's picture. Originally the part was too rusted to work properly, even though I tried cleaning it up with a wire brush and sandpaper it would still only work most of the time and if you pushed on the horn button in certain places. I bought a new reproduction piece and when I put it in the horns were hot all the time. I finally figured out that the contacts that were separated by the plastic piece were actually touching when I put the horn cap on, once I did some bending and tweaking it works fine now, but it don't take much to blow the horn, hope this helps you both
Old 11-24-2012, 04:02 AM
nz corvette
Thanks for that,just checked it out an have it all sorted
cheers airborneSilva - nz covette
Old 11-24-2012, 04:28 AM
AirborneSilva
Sweet, glad I could help
To Where is the horn Relay?
Quick Reply: Where is the horn Relay?
