Speedo not reading correctly since cable was replaced.
The cruise control was removed and a one piece cable was installed from tranny to speedo head. It worked on the lift then read incorrectly for a few miles now the needle just floats at around 10-30 mph at highway speeds. Do you reckon the drive gear in the tranny stripped, or what? Had a difficult time plugging in the cable at the speedo head so maybe it popped out???? Will check that first.
1 Post
I think it probably popped out of the speedo. There is a clamp thingy on the back of the speedo that holds it on there. Make sure you really push the cable into the speedo good and tight.
I know that my gear in the tranny is stripped (the one you have to pull the rear of the tranny off to replace I think) and my speedo does not register anything.
Difficult to reach with full grown man arms! May buy a little monkey to do it.
1 Post
I found it easier to drop the duct out of the way that goes below the steering wheel. If you reach up there you can feel the clamp. It is like a circle that is bent out on one side and when you push the cable in, it clamps over it. One more trick I did was take out the little vent by your left knee and you can put your hand in there and do it and you will see what I am talking about.
