Stewart Stage II Pump Rubbing Pulley
I just received my new Stewart Stage II Aluminum water pump today. When I test fit everything up, I notice that the stock pulley rubs the housing at the heater house fitting. I mean it just makes contact. Has anyone had this problem? I was going to get an aftermarket billet pulley, will this help? Should I slightly grind away the point where the contact is made? Do they make shims? Im talking 1/16 would be more than I need to clear it.
Also, where can I get a new heater hose fitting and plug for the yop of the pump.
- X
- X
You can grind it, or you can purchase waterpump shims that will move the pulley away from the pump housing. They come in a 3-pack, different sizes, and fit between the pump pulley and the pump shaft. I bought mine at Auto-Zone - less than $5.00.
Ok, I saw a few other posts on the topic. Guess it is somewhat common.
Any ideas if a new pulley would help? Was going to get one to dress the front up a bit. Should I stay away from the 50 dollar ones I see on Jegs and eBay for fear of poor quality?
Any where can I get the plumbing hardware from?
I would think most pulleys are fine - they are all one piece stamped metal. Plumbing fittings can be found at any hardware store, or the usual car parts stores.
If I get a new pulley, I would go wth an Aluminum machined one. Some people have said that the cheap ones are junk and may have quality/balance issues.. I dont see how if they are machined.
let me guess the heater hose boss doesn't have a indentation like chevy pumps have and its rubbing on the back of the pulley, once you file it its yours, I had the same problem with another after market pump odds are made in China, I returned it and got a Edel pump and it fit right, the heater boss may look thick but remember its Alum. and if you deduct for the 1/2" pipe threads cut into it its really not that thick I was worried about cracking when I tighten the hose adapter in if I filed on it, the spacer kit comes in 1/16, 1/8. 3/16 or a combination there of, you might be able to get away with a 1/16 wp shim anymore then that most likely you will have to shim the rest of the pullies, the plug for the top of the pump is I believe 1/2" pipe, another thing to think about on those billit pullies are they are about a 1/4" thick at the mounting, make sure you have more than a 1/4 from shaft flange to the end of the shaft so you have enough shaft to center your fan, I've seen people have problems when shimming a billit pulley.
I tried to find my pictures of how I machined my water pump on a verticle mill
I used common pipe thread bass plugs.
Machined on a Vertical mill for pulley clearance
