Engine Smoke .
Engine Smoke .
Driving down the road i noticed smoke coming out of my hood. I pulled over and heard a hissing sound and immediately assumed it was my valve cover gaskets..header..etc. It turns out to be a little hole withhin that circular groove thats between your water pump and your steering pump. The smoke is white and the contents it leaves on the ground is water and not oil however i'm assuming the oil is just runoff. Any ideas?
Are you referring to a freeze out plug on the engine block?
I'm not trying to make fun of you, so please don't take it that way, but I have no idea what you mean by "that circular groove thats between your water pump and your steering pump." Could you try to describe it another way?
Keep the shiny side up!
Scott
Scott
Received 1,470 Likes
Cruise-In II Veteran
Check your coolant level. That was not white smoke you were seeing; it was steam. There is a water jacket behind the freeze plug.
You can buy an actual freeze plug tool, but it's not critical.
Before you change out the plug are you sure it's not the water pump weep hole leaking onto the block. The weep hole is there to show the seal is leaking internally.
Buy a freeze plug kit for small block Chevrolet. A hammer is not what you want to use directly on the plug. Put sealant on the edges of the plug, use a large socket on the plug, and tap the socket to seat the freeze plug.
water pump weep hole? I am assuming this hole is on the water pump. the steam is comin right from the middle of the freeze plug. I'm looking up how to remove the plug via Google now.
Heres the photo. The the circle/hole where the steam is coming from.
http://www.flickr.com/photos/58854115@N03/6852471100/
Yuck But easy fix,Just lever it out and do what Mike said above.
The other plugs wont be as easy to get at, and you might want to clean that engine before you start
...so I can set the socket onto it?...
Google Replacing Freeze Plugs and see what you get.
Most pros use Permatex High Tack Gasket sealant or Indian Head.
Chances are high that the rest are in close to the same condition.
There are 2 between the tranny and engine, so keep an eye out.
If you can't drive a new one in, then this type is a permanent solution.
Here's how I did it on my Jeep.
http://s413.photobucket.com/albums/p...1119165615.mp4
http://s413.photobucket.com/albums/p...1119170024.mp4
I tried to get the freeze plug off and I punctured a hole through it! I tried using needle nose pliers to take it off but to no avail. any suggestions?
http://www.flickr.com/photos/58854115@N03/7000903933/
