Setting ZZ4 initial timing
Old 03-18-2012, 06:27 PM
TWINRAY
TWINRAY's Avatar
Default Setting ZZ4 initial timing
Now that I'm getting close to starting the motor, I (just) noticed there is no (?) tab on this motor like my original oem 1969 SB so you can set timing at idle. It calling for 10 degrees BTDC. The timing indicator just has an "arrow cut" instead of a tab in degrees before and after TDC. Now, I could make a tracing of the tab on the oem motor and get a pretty good idea where the flash point for 10 degrees BTDC would be but is there a more correct way of doing it. In addition, for timing at 4K, which I think they say is 35 degrees, what is the procedure for this?
Old 03-18-2012, 06:32 PM
alswagg
alswagg's Avatar
The harmonic ballancer should have a timing tape, with degrees. Are you using a new ballancer for a ZZ4? How about the flywheel, this is an externally ballanced rotating assy. Al
Old 03-18-2012, 06:36 PM
TWINRAY
TWINRAY's Avatar
It's the factory balancer - its an assembled 355 hp ZZ4 - no timing tape is on the balancer. So I just have to get some "timing tape" and affix it to the balancer? Thanks for the quick reply
Old 03-18-2012, 08:25 PM
drwet
drwet's Avatar
The timing tape is the best solution. Verify top dead center before you install the tape. The factory mark can be out a degree or two. You might as well get it right.
Old 03-19-2012, 09:15 AM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
Timing tape or an adjustable timing light would be what you need. I use to use an adjustable craftsman light I had to set mine.
Old 03-19-2012, 01:42 PM
TWINRAY
TWINRAY's Avatar
Thanks, got it figured out
To Setting ZZ4 initial timing
Quick Reply: Setting ZZ4 initial timing
