Best Radiator Fans for a 350 Small Block?
TheCorvetteBen
So we are nearing the final stages of getting my 75 back up and running and the last thing I need to buy (fingers crossed) is the electric fans that go over the radiator in order to eliminate the mechanical fan.
The question I have is, what were the fans other members have installed, type, brand, price? What issues have you found? What has worked for you?
I gonna buy these really soon, so your input is appreciated.
Thanks!
Thanks!
Is there a noticeable change in the sound of the engine with the mechanical fan gone ? Like, is the vacuum cleaner-like sound gone ?
Also, if I make the swith to electrical, how difficult is the radiator swap/fan installation ?
I think many here have used the newwer Corvette fan and also a Mark 8 fan. So if there is a salvage yard near you can do that. Not a simple bolt on item if I remember correct.
TheCorvetteBen
Here is the rad that I have. It is a Chinese aluminum one off eBay. I bought it when I didn't know any better, BUT its worked pretty well. Will the SPAL fans attach to this one?
If you are interested in retaining a belt driven fan, I have a Flex-a-lite 7 blade 18 inch fan. It has never been used and has large stainless blades to move a ton of air. It comes with a variety of spacers so you can get the right distance from the radiator. $35 + shipping.
What's the benefit from running two 10" fans for an A/C car vs one 16"?? Are you not cooling a larger surface area with the 16" Looking at the numbers yes 20" is larger than 16" but with the 10"s in two different locations wouldn't that leave more area of the radiator not covered??
But who am i to say , i have ac and run a single 16"spal. if ac is on the fan is on .
These duel flexies ones work well.
But the left one broke after 4 months.
underneath
An email to techy dept. revealed that maybe because I run a mechanical fan as well it may be pulling too hard on the duels
Reason for mechanical..cheap insurance..it wont blow a fuse or fry a controller unit wilst I'm looking at *** instead of a guage
underneath
St. Jude Donor '09
If budget is a consideration, then either used Taurus or Mark VIII fans are good reliable choices. I used a Taurus fan. Either can be wired with the correct relay to include the A/C trigger.
Dual or dual speed fans obviously add to the wiring complexity.
But I have read some say certain years are duel speed and others not. Is that true and what years are best to get?
Right now I'm running the factory setup with an added 14" fan inside the shroud opening with no problems what soever other than the clutch is going bad. BUT, when I take off the mechanical fan and just run the electric at idle it runs hot. That's one reason I'm looking into just electric fans (for more space under the hood) and I have to buy the clutch or I can get the electric ones for free. Also, if you run electric fans whether 1 or 2 should you also try to use a shroud for them??
