Rebuild my clock
Are you looking to keep it original for judging or looking to get to functioning? If it's the latter, get a quartz replacement from any one of the large vendors. The swap out of the movement is pretty quick. Jerry
Greg (10-18-2023)
Just another Corvette guy
This ^^^^
And it will keep working.
I've repaired the original works a few times but sooner or later they all fail again. It's just the nature of the design with the arcing points starter.
I install a quartz movement in all my Corvettes. They all keep perfect time.
try it yourself.. not hard..
still ticking here trick is to use clock oil after cleaning
https://www.corvetteforum.com/forums...ck-repair.html
Hopper12 (10-18-2023)
Received 4,459 Likes
Cruise-In VIII Veteran
Another vote for the quartz movement. The convertion is easy and lasts. Mines been keeping perfect time for nearly 30 years now.
clock repair
Here's my post from 2020 showing everything you need to do it yourself.
Original Clock Repair - CorvetteForum - Chevrolet Corvette Forum Discussion
clock rebuild
I just rebuilt my 69 clock yesterday with a quartz conversion kit I got from baire's in PA. nice and easy. took more time to get the case apart than to convert it. if you can read instructions and interpret a drawing you're good to go. did the same years ago when rebuilding my 78 pace car. clock still worked when I sold it 10 years later.
