Wiper switch replacement
Old 03-02-2012, 04:06 PM
78 silver 78
78 silver 78's Avatar
Default Wiper switch replacement
Can you replace the switch from no pulse to one w/pulse ? Do i need to change the controller ? When i got my '78, the PO gave me alot of new parts still in their box's. One is a new AC Delco Switch,Wiper w/Pulse,78-82. I'm hoping to use this with out having to replace a lot of things.
Thanks,
Ken
Old 03-02-2012, 06:17 PM
KapsSA
KapsSA's Avatar
Just changing to a "pulse" switch will not give you intermittent wipers.
There is a module under the radio with about 15 wires going to it for the intermittent system.
The switches may be interchangable if you just have a bad switch, don't know for sure.
Old 03-02-2012, 08:06 PM
78 silver 78
Thanks. My A.I.M. only shows the "pulse". The switch that is in the car works but has rust.
Ken
Old 03-03-2012, 10:17 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by 78 silver 78
...The switch that is in the car works but has rust...
My advice would be to leave it alone for as long as it works. Hang on to your replacement switch until it's needed. Most 78s had intermittant wipers.
To Wiper switch replacement
Quick Reply: Wiper switch replacement
