Dial back timing light????
Old 02-28-2012, 03:28 PM
mk's78
mk's78's Avatar
Default Dial back timing light????
Hello fellow c3'ers,
I am trying to find any source for the purchase of a dail back timing light and I am lost. Perhaps I am not looking for the correct name etc..so if anyone could give me a part name, part number or even a sku code I would really appreciate it. I've looked at AutoZone, Pep Boys and Sears websites and cannot seem to narrow it down to a specific "dial back timing light".......they just show timing lights so I am not sure what look for.
Thanks all in advance....
mk's78
Old 02-28-2012, 03:44 PM
terry82
terry82's Avatar
http://www.summitracing.com/search/P...Timing-Lights/
Old 02-28-2012, 03:48 PM
Bruthish
Bruthish's Avatar
St. Jude Donor '03-'04-'06-'08-'09
I bought the best one Pep Boys had...$99 I think..it has worked more than perfect for me.
Old 02-28-2012, 03:55 PM
billla
Support Corvetteforum!
billla's Avatar
St. Jude Donor '14
Pick your price I like the Equus ones with the built-in tach.
Old 02-28-2012, 04:26 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
The 'dial back' timing lights will have a ****/dial on the rear of the light. That **** is what you turn to dial-in the number of degrees [advance] that you desire. Or, you just aim at the timing indicator (at the damper) and turn the **** until the TDC line on the damper lines up with the "0" degree mark on that indicator. Then read the number of degrees on the timing light dial and that tells you the degrees advance that your engine is producing at that time.
I think that all of the 'chain' auto stores sell them. Or you can find one on Amazon.com or eBay.
Old 02-28-2012, 04:34 PM
Mashman
Mashman's Avatar
I got a Craftsman from Sears, it has worked great for a number of years.
http://www.sears.com/shc/s/p_10153_1...=1330464816726
Old 02-28-2012, 04:46 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,246 Likes on 966 Posts
Default Best invention since sliced bread!
Originally Posted by 7T1vette
...just aim at the timing indicator (at the damper) and turn the **** until the TDC line on the damper lines up with the "0" degree mark on that indicator. Then read the number of degrees on the timing light dial and that tells you the degrees advance that your engine is producing at that time.
Thats just the way I do it.
MK's78 check out the one Mashman posted, the small picture on the bottom shows the dial.
Old 02-28-2012, 04:55 PM
Rally68
Rally68's Avatar
I have the $55 one with the metal housing from Summit, it has performed well for a number of years.
Old 02-28-2012, 05:12 PM
Tim H
Tim H's Avatar
Originally Posted by mk's78
Hello fellow c3'ers
mk's78
You just said it in your last sentence "advance" as in "advanced timing light".
I have a Sears chrome one and it works good.
Companies also make digital ones.
Old 02-28-2012, 08:06 PM
LongIsland C3
LongIsland C3's Avatar
You can get the $475.00 Snap-On timing light like me, or, you can be smart and buy a Craftsman, Pep Boys, and I think they even have them at Harbor Freight. My hopeless tool addiction! Unless you're going to use it each and every day,the models listed earlier in this post will suit you just fine.
Old 02-28-2012, 09:23 PM
noonie
noonie's Avatar
I've got this one, does rpm, charging volts, timing advance, works with all types of ignitions. I forgot it even does dwell, it's been so long. Google for better price.
http://www.summitracing.com/parts/EQU-5568/
Old 02-28-2012, 10:19 PM
BLOCKMAN
BLOCKMAN's Avatar
http://www.dragracingonline.com/tech...-lights-1.html
http://www.chevytalk.org/fusionbb/sh...hp?tid/173877/
Old 02-28-2012, 10:28 PM
1Fordman
1Fordman's Avatar
This is an excellent tool to have.
Old 02-28-2012, 10:32 PM
C3 4ME
C3 4ME's Avatar
I too bought mine from Sears. It has worked perfect for several years now.
Old 05-18-2013, 06:50 PM
madvette74
madvette74's Avatar
Can a dial back timing ligbt be used with msd boxes?
QUOTE=mk's78;1580138096]Hello fellow c3'ers,
mk's78[/QUOTE]
Old 05-18-2013, 09:44 PM
7t9l82
7t9l82's Avatar
i have never used a dial back light , i have an old sears that i extended the power lines so i can clip it to the battery terminal in a c3. people in my area years ago called it a "corvette timing light". don't know if its better or not but it always helped me make the car run better.
Old 05-19-2013, 12:44 PM
lars
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,925 Likes on 1,930 Posts
There's no need to do that. Just clip the timing light onto the positive terminal on the back of your alternator, and clip the negative wire onto any metal engine part.
Lars
To Dial back timing light????
Old 05-19-2013, 02:05 PM
Eddie 70
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Lars
I have always done what Lars said. I have reclocked this alternator so be careful and pay attention to your connections, not mine.
Old 05-19-2013, 03:24 PM
dtamustang
dtamustang's Avatar
i guess i'm a relic,i don't have a dial back light,mine is an antique that i have used for about 30 years,as well as an antique snap on dwell meter and tach.but i'm not completely in the stone age , i do have the luxury of a distributor machine.
Old 05-19-2013, 05:59 PM
7t9l82
7t9l82's Avatar
not one to argue with Lars, i am not. but 30 years ago some of us believed that the terminal (could )interfere with the signal from the timing light causing us to extend our connections. not saying it turned out to be true just saying thats why we did it . i trust what Lars says, sometimes old school isn't the best school.
Quick Reply: Dial back timing light????
