running lights on a 75
I am having a problem with the running lights on my 75.
The fuse is good but none of the lights will work.
Could it be the light switch itself ?
Any other possibilities ?
thanks for the help
thanks for the help
Does that include your head lights. It could be a bad headlight switch or a connection at the headlight switch. or at the fuse box or some other place but I would look at the switch first.
I found the problem. The NEW headlight switch I installed had a loose terminal connection.
Replaced the switch and everything works. Lesson here was don't ASSUME a new switch is good.
