Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2012, 09:04 AM   #1
marshal135
CF Senior Member
marshal135's Avatar
Default No leak valve cover gaskets?
If there is such a thing I'd like to know about them.
1968 427 w/ orig covers.
Current gaskets permit dripping down the exhaust manifolds dirtying up my engine
Thanks,
Marshal
marshal135 is offline   Reply With Quote
Old 02-02-2012, 09:17 AM   #2
oneshot
CF Senior Member
oneshot's Avatar
Might want to look at some Felpro gaskets. I know they make a oil pan gasket that has a metal core so you can tight them up but not pitch the gasket. They might make one for valve covers.
oneshot is offline   Reply With Quote
Old 02-02-2012, 09:42 AM   #3
Surfer69
CF Senior Member
Surfer69's Avatar
I have to say I've tried everything, cork, rubber, tall short, new valve covers and my AFR heads would still leak at the rear corner.
Even with or without a dab of sealant. And at $10 a pop or more it becomes a real pain.
But I noticed that there was always this more expensive set from Felpro (I think, can't remember now) around $20 and it's made of rubber with kind of fins going around it. At the fastener locations they have metal rings so you can't overtorque the thing. I've had these 6 months now with synthetic RP and no leaks.
I'm pretty sure I found the perfect valve cover gasket.
__________________
(69 conv 383 AFR195 Perf RPM,DT hdrs,UltraFlows,4spd 3.36 D.D.)
Surfer69 is offline   Reply With Quote
Old 02-02-2012, 09:45 AM   #4
jcloving
CF Senior Member
jcloving's Avatar
I have some felpros on my engine. They are injection molded rubber over steel. They recommend applying them on a dry clean block and valve cover with no sealant. I have used them for over a year with no leaks.
I believe these are ones I have:
http://shop.advanceautoparts.com/web...___#fragment-1
They are a bit more pricey but are reusable and work for me!
jcloving is offline   Reply With Quote
Old 02-02-2012, 11:23 AM   #5
qwank
CF Senior Member
qwank's Avatar
I use these on my '81 with great success also
qwank is offline   Reply With Quote
Old 02-02-2012, 11:34 AM   #6
anips
CF Senior Member
first of all you have to make sure the V.C. rails are straight specialy at the bolt holes, I use either FP #1604- $33 or Mr Gasket ulta seal $23. they are both 5/16" thick with a steel shim, I use 3M spray adhesive to glue to the cover, and just a smire of rtv and I mean JUST a lite smire on the gasket-head side, and make sure the head rail is clean and dry before bolting on, never a leak, and later when you might have to remove the cover you might have to tap the cover to get it to come loose from the head,after that just bolt em back on.
anips is offline   Reply With Quote
Old 02-02-2012, 12:11 PM   #7
BarryK
CF Senior Member
BarryK's Avatar
for what it's worth... when I was re-doing the motor and engine bay on my '78 a few years back I decided to use a set of expensive Felpro gaskets for the valve covers since I already had them new in the package. These were a "sandwich" type of gasket with a thin piece of metal sandwiched between rubber. Sorry, don't remember the model number..
These expensive gaskets leaks like a sieve all over my fresh and newly painted motor and nothing I did would get them to stop leaking.
I'd always used the basic cork gaskets on my '65 and never had a leak from the valve covers at all so I got another set of cork gaskets for the '78, put them on, and the motor hasn't leaked a drop out of thr VC's ever since
BarryK is offline   Reply With Quote
Old 02-02-2012, 12:15 PM   #8
billla
CF Senior Member
Support Corvetteforum!
billla's Avatar
Send a message via MSN to billla
I have personally never had a problem using the "old skool" cork gaskets. I Permatex them to the cover, and then tighten *just so*.
For stock and mild engines with tin covers, the most common cause of leaks are bent rails (or dimples at the bolt holes), over-tightening or failure to install the spreaders. They don't need to be brutally tight!
billla is offline   Reply With Quote
Old 02-02-2012, 01:06 PM   #9
BarryK
CF Senior Member
BarryK's Avatar
too many people overtighten the bolts and it causes leaks. just snug them down lightly
Old 02-02-2012, 02:37 PM   #10
marshal135
CF Senior Member
marshal135's Avatar
Thank you everyone for your time and responses.
I think the area on the VC's around the bolt holes is probably dished in from overtightening in the past.
I'm going to check the rails when I pull em off.
I like the idea of adhering them to the VC and dropping in place.Some of my spreaders must have gotten lost because there are several bolts with round washers under them.
I'm going to order a new set of bolts with spreaders for a cleaner look.
I think cork replacements are on it now and are letting some oil sneak by on the lower edge of the head. I read the torque value for valve covers is like 10inch/lb so not allot needed to seal them.
BarryK, I enjoyed your timing article. I learned allot and read it like 4 times so I'm ready to tackle the timing this spring with the article on the fender next to me
Marshal
Old 02-02-2012, 02:52 PM   #11
billla
CF Senior Member
billla's Avatar
Quote:
A few careful moments with a ball-peen hammer and a scrap of 2x4 will fix that right up
Old 02-02-2012, 04:14 PM   #12
birdsmith
CF Senior Member
birdsmith's Avatar
A little trick that I invented was to check around the cover with a .0015" feeler gage as you slowly tighten it. Cork gaskets will not leak as long as there is no gap between them and the head mating surface. too often the valve covers are distorted from previous Bubbas. And I don't use RTV on them ANYWHERE. I glue the gaskets to the valve covers with yellow 3M weatherstrip cement, which keeps them tightly in place so they don't move around or creep while you are [carefully] tightening them. That is all...
birdsmith is offline   Reply With Quote
Old 02-02-2012, 04:36 PM   #13
forman
CF Senior Member
forman's Avatar
I use the felpro blue ones they have the metal in the middle , just make sure the valve cover edges are not bent or warped or they will leak like a sieve no matter what you do
forman is offline   Reply With Quote
Old 02-02-2012, 06:36 PM   #14
Ironcross
CF Senior Member
Ironcross's Avatar
Default One of my PRO tips
it really does not matter what brand of gasket used, Felpro, Victor, McCord or what ever...its the technique used and most will never follow this....do all the prelimination necessary, clean parts ect....use a hard setting sealer, your yellow 3-M trim cement is a good one {08011} I think...AND on the valve cover only, spread the glue all around the valve cover gasket lip until its real tacky but not quite dry...place the gasket on that surface and with whatever weighted objects hold the gasket in place several places so it will not move...When completely dry install the gasketed valve cover in place and put the screws back in....and do not over tighten....No silicone is necessary..ever and NOTHING on the head except some bearing grease...
Ironcross is offline   Reply With Quote
Old 02-02-2012, 06:57 PM   #15
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
I've had motors you could run with valve covers off with high rail heads.
The problems many of us face is the oil return on AFR heads. If you have ever looked closely at it, it is just below horizontal. What happens is the oil is not drained well from the head and collects in the corner and overflows the rails.
Any pinhole sized hole and you have a leak. I have had a leak on both sides on my AFR 227's since new. I have tried everything and every gasket I even put Permatex #2 on both sides of the gasket and it still leaked. Brand new heads, brand new valve covers, brand new gasket and oil on my garage floor.
What is the part # for the ribbed one with the washers ?
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage......................................My'70 CUDALotsa ladies and lotsa trouble
MotorHead is offline   Reply With Quote
Old 02-02-2012, 07:25 PM   #16
noonie
CF Senior Member
noonie's Avatar
Here are the good Felpro
They come with spreaders that are longer than stock (black)
The really long spreaders are oem GM (on cover) from around 1980.
No probs with these at all.
Click the image to open in full size.
If you find that nothing works, use Permatex Great Stuff (???). I use that on problem tranny pans immersed in oil with never a leak.
noonie is offline   Reply With Quote
Old 02-02-2012, 07:42 PM   #17
Will's'74VetteL-82
CF Senior Member
Will's'74VetteL-82's Avatar
William Harkness Boop5 Boop334
I use Felpro cork gaskets with and RTV bead around the rim of the VC (which are aluminum L-82 valve covers). I currently have the normal thickness gaskets on, but I also bought another set from my Corvette shop that I use and they are thicker cork gaskets, both Felpro though. I used a 1/4 inch nut driver and tightened the bolts with that to a good torque to compress the gaskets, and I have no leaks since the install.
Will
Will's'74VetteL-82 is offline   Reply With Quote
Old 02-02-2012, 08:40 PM   #18
C3 4ME
CF Senior Member
C3 4ME's Avatar
Just re-did mine last night for the exact reasons listed. I have stock aluminum covers, I placed both on a piece of flat glass, and both are dead flat. I tried Fel-Pro rubber gaskets this time. I have always put RTV on the covers only, so as to be able to remove them without damaging the gaskets. I had cork ones on before, so we'll see how the rubber ones do. I'm starting to think the only way to keep them from leaking is to not have any oil in the engine, lol.
C3 4ME is offline   Reply With Quote
Old 02-02-2012, 09:03 PM   #19
billla
CF Senior Member
billla's Avatar
In aviation, we call this "automatic airfame lubrication" :-D
Old 02-02-2012, 09:30 PM   #20
Steve2147
CF Senior Member
I would estimate that the single biggest cause of leaks, sweating, seepage from gaskets is failing to properly clean the surfaces.
In order for any of those gaskets to work the surface has to be free of any traces of oil. I use CR brand Brak-kleen (sp?) in an aerosol and spray liberally, then blow it off with air. If you have to glue the gaskets for ease of assembly I use 3M weatherstripping adhesive and glue the gasket the cover. The other side is left dry.
Same if you choose to use RTV sealant. If both sides are dry you don't even need bolts. Glass shops use that stuff to glue mirrors on. If you've ever had to remove covers that were siliconed on you know exactly what I'm talking about. The only thing they did any different was put it on clean dry surfaces.
Steve g
Steve2147 is offline   Reply With Quote
Reload this Page No leak valve cover gaskets?
Tags
1973, 1980, c3, clear, corvette, cover, forum, gasket, gaskets, leak, leaking, mccord, problems, rockers, sbc, shaft, td, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
