Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-01-2012, 07:05 PM   #1
waid1017
Junior Member
Default Keep my Quadrajet or get another carb for 350HO Vortec ?
After a lot of research on the web, I am planning to replace the top end on my 350 V8 and replicate GMPP 350HO Vortec. Based on the Car Craft’s article, I should be at a minimum of 350hp (I hope ). I think this is the best bang for the buck.
http://www.carcraft.com/techarticles...e/viewall.html
http://www.carcraft.com/projectbuild...l/viewall.html
GMPP Stock Vortec Heads (#12558060)
GMPP Cam (#24502476)
The above heads & cam comes in the GMPP 350HO motor
Edelbrock RPM Air Gap or Performer Vortec.
Fel-Pro 0.15” shim head gasket to bring up compression to around 9.1-9.5 :1
Long tube headers
I rebuilt my Quadrajet and works just fine. Is it worth replacing it with a Holley 750 cfm or another Carb?
My 350 V8 is actually in a 1977 Olds Omega (Nova) so I dont know if there is any difference in post 75+ carburetor.
Thank you very much
Waid
waid1017 is offline   Reply With Quote
Old 02-01-2012, 11:14 PM   #2
Ben Lurkin
CF Senior Member
St. Jude Donor '09
Ben Lurkin's Avatar
I don't remember if anyone makes a spreadbore intake for vortec heads. If so, keep the qjet.
Ben Lurkin is offline   Reply With Quote
Old 02-02-2012, 06:30 AM   #3
Vette5.5
CF Senior Member
Nope. Nothing else out there like a well tuned Q-Jet. These are very complex carbs, and may take some doing though. Guy's like Cliffs carbs and Lars Grimsrud can help you along. Well worth the effort, as you'll be showing most the other guy's tail lights.
Vette5.5 is offline   Reply With Quote
Old 02-02-2012, 08:39 AM   #4
thegazman
CF Senior Member
thegazman's Avatar
Quote:
You buy Performer spread bore intake for Vortec heads.
thegazman is offline   Reply With Quote
Old 02-02-2012, 08:46 AM   #5
jackson
CF Senior Member
Sounds like a good plan.
Keep your good-running spreadbore QJet.
Shortest vortec spreadbore intake is Professional Products cyclone 52007 ... it's very similar to EB2116 but a bit shorter; less $ too.
unless stock vortec heads are retrofitted with guide plates, '77 sbc rocker arms will not work (for long).
suggest a new set of pushrods (no need for race quality here) and a new set of "self-guided" aka "rail-type" aka "self-aligning" rocker arms as found on later heads (/350HO) ... maybe even 1.6:1 rar (no need for roller/roller tip rockers here).
like any brand new flat tappet cam, x476 also requires brand new lifters.
jackson is offline   Reply With Quote
Old 02-02-2012, 12:16 PM   #6
vanice
CF Member
When I did my vortec swap in my 77 zz4 I used GMPP vortec manifold 12486570 it will accept square or spredbore carbs. It also has an egr port. I stuck with a quadrajet and it work very well. I don't know if this manifold is still available. I have a spare new takeoff manifold on C/L
vanice is offline   Reply With Quote
Old 02-02-2012, 01:45 PM   #7
waid1017
Junior Member
Vanice, did you end up adjusting/changing anything on the Quadrajet?
What cam did you use?
Most likely, I will end up getting the Edelbrock 2116 - Edelbrock Performer Vortec Intake Manifolds Spreadbore which is cheaper than the GMMP and it too will accept both spreadbore and square.
Old 02-02-2012, 02:01 PM   #8
billla
CF Senior Member
St. Jude Donor '14
Support Corvetteforum!
Send a message via MSN to billla
The Q-Jet is a great carb - one of the all-time best street carbs.
I can't imagine that it wouldn't need a tune from the change, and there aren't that many folks around that have the knowledge and parts to do so - that's the only potential downside.
billla is offline   Reply With Quote
Old 02-02-2012, 02:37 PM   #9
waid1017
Junior Member
What do I do about the choke heater tube?
Old 02-02-2012, 03:39 PM   #10
mrmagrath
CF Senior Member
mrmagrath's Avatar
Grant Magrath
My 74 has a 78 q-jet. It came that way when I bought it, and as such, the manifold is setup for a divorced choke, and the carb has the hot air one, so I fitted an electric choke. Problem solved until a 74 auto q-jet pops up!
mrmagrath is offline   Reply With Quote
Reload this Page Keep my Quadrajet or get another carb for 350HO Vortec ?
Tags
350, bore, c3, carb, carbs, choke, corvette, devorced, heads, intake, performer, qjet, quadrajet, spread, vortec, vortech, vsother
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
