accelerator cable set uo
Old 02-02-2012, 12:32 PM
smyth1
smyth1's Avatar
Default accelerator cable set uo
i'm having trouble with cable travel on my holley 3310.i'm using the stock small block bracket with a new cable but cant adjust it to go to wot and back to idle.im on the furthest hole on throttle lever.anyone know what the lt 1 setup is? any suggestions would be greatly appreciated.thanks
Old 02-02-2012, 03:39 PM
MelWff
MelWff's Avatar
Received 1,823 Likes on 1,611 Posts
are you using the stock bracket for a Holley? the Quad used a different one.
Old 02-02-2012, 04:13 PM
smyth1
smyth1's Avatar
i'm using the bracket that was on the q jet.is there a different one for the holley?is the cable the same or is that different as well
Old 02-02-2012, 04:27 PM
Phil Zell
Phil Zell's Avatar
Get a bracket for an early LT-1, as in 1970, they had holley carbs. Your old cable should work
Dr. Rebuild has these as a rule
#3459210, 3425213, 3425199, and 3425225
To accelerator cable set uo
Quick Reply: accelerator cable set uo
