Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-12-2002, 05:53 PM   #1
candyapplevette
CF Senior Member
Default setting air/fuel screws on Holley carb.
What is the correct way to set and adjust the air/fuel screws on a Holley 750 double pumper with the 4 corner idle system?
I have been told by some local people to set all 4 screws the same and I have also been told to set the back ones approx. 1/8 to 1/4 turn out only.
What is the proper way to set this carburator? All of the Holley's I used to run were the old style with 2 air/fuel screws.
candyapplevette is offline   Reply With Quote
Old 05-12-2002, 06:18 PM   #2
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: setting air/fuel screws on Holley carb. (candyapplevette)
Just adjust them for the smoothest idle or if you have a vacuum gage then obtain the highest vacuum reading. ;)
Larry B. is offline   Reply With Quote
Old 05-14-2002, 04:01 PM   #3
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
All the holleys I have delt with idle too rich. I usually have a healthy cam so it doesn't help. I always drill about .100 hole in each of the throttle plates. The placement is important. I then install a .015 wire in each of the idle circuit passageways. You are trying to establish 1 1/2 turns out from bottoming the idle screws. This is where they are ment to be. If they are almost closed to get a descent idle something is not right. The throttle plates should also be closed. Too open and the transferr slots start adding to the idle mixture. I the throttles are uncovering the transferr slots the idle screws will be insensitive.
I set front and back the same. Try for the best idle at around 1 1/2 turns.
norvalwilhelm is offline   Reply With Quote
Old 05-14-2002, 07:42 PM   #4
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Default Re: setting air/fuel screws on Holley carb. (norvalwilhelm)
First I turn all screws 1 1/2 turns out then get the vacuum gauge and since I only have two hands I set the primary first then the secondary :D
[Modified by MotorHead, 5:43 PM 5/14/2002]
MotorHead is offline   Reply With Quote
Old 05-14-2002, 08:31 PM   #5
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
take the carb off the engine,set the idle speed screw so only .040 of the idle transfer slot is showing. set the butterflys on the secondary side to be open the same amount. install the secondary stop screw in upside down so you can turn it from the top. put the carb back on and if it does not idle fast enought take it of and drill all 4 butterflys with a 3/32" drill about 5/16" of a inch from the edge,centered towards the outside edge of the butterflys. all DP are very rich on idle and you can put the wire into the IFR or solder them up and redrill them smaller :chevy
clem zahrobsky is offline   Reply With Quote
Reload this Page setting air/fuel screws on Holley carb.
Tags
air, airfuel, c3, carb, corner, corvette, fuel, holley, idle, number, performance, ratio, screws, setting, settings, terms, turns
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to Set up & Install a 750 Speed Demon on a 350 (dial-up beware) lars C3 Tech/Performance 49 03-08-2004 07:49 AM
Having some tuning questions. LAvetteman C3 Tech/Performance 11 10-13-2003 09:21 PM
BG Speed Demon Carb Setups lars C1 & C2 Corvettes 10 02-24-2003 05:10 PM
Basic BG Speed Demon Carb Setups lars C3 Tech/Performance 20 02-21-2003 12:22 PM
Holley adjust-a-jet kit ? SmokedTires C3 Tech/Performance 16 06-06-2002 10:36 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
