About to start the big block swap.
Nice. I see a bit of grinding work on the heads as well. Did you port them yourself?
You won't have to worry much about your hood if it's the factory one. It won't fit with that intake.
Good Luck btw.
Good Luck btw.
And with the headers bolted on. That is first. Good job if ya got it in. Any issues mating the trans to the engine with the middle hook on the intake lift plate?
Thanks guys. The motor felt like it wouldn't set on the motor mounts at first. Kept at it and finally got it in with the first hole on the lift plate .I took the passenger header off to finally get the motor in.
Update
Got the engine in . Now to rewire the spaghetti wires all over. I also need to connect the fuel lines and mallory reg. I've got it temporarily connected to get it started and hear the engine roar.
#33
One thing that happened was , I kept getting a popping out the headers which was scaring my wife every time it happened. I'm thinking maybe a lean misfire? Well , found out I crossed the wires . Weird thing is at the very end I took in a few beers and what supposed to be a 4-7 swap turned out to be a 5-7 swap. Put them correctly and no more popping.
#34
looks good. Was wondering is that the electric fuel pump you have mounted next to the alternator ? If it is, Just an Fyi, electric fuel pumps are better pushers not pullers.
#36
That's actually a holley fuel pump regulator with a home made "plug" . The regulator is coming off for a mallory one.
#37
I have a complete 454 fan to tran, just pulled from a 78 truck. Will any of those brackets work in my 75 swap? I'm hearing a lot of different info, but appreciate it all. Thanks
#38
Im very familiar with the long pump and brackets as i just sold one set for a truck BB conversion.. by scappys pic i think the ps and the a/c compressor will work... electric fans are a must..... put the BB in and see what happens..... good luck.. im going with a serpentine on mine...
#39
well if ya look at scrappy76 previous pic, that is a long passenger car/truck style alternator mounted on the right with a long standard rotation water pump.... im almost sure he cut the notch in the frame for the longer crank pulley... not a problem for me some just cringe,but you do what ya want i did....
