Radio Noise
Radio Noise
Hey Folks,
Here is what I have going on with my car. I recently redid the majority of my interior and in doing so I added an Alpine stereo with Pioneer speakers (4x6 in the front and 6x9 in the storage area).
My issue is that when I first installed everything and got the car back on the road I had no noise through the radio. About a week later I started getting a noise that sounds like engine noise through the speakers, but it is intermittent. Like today I ran to the grocery store and took the Vette. When I left the house it had the noise and it was fairly loud, by the time I got to the store (about 4 miles away) the noise was still there but reduced in volume. When I came out of the store there was no noise at all, it remained that way for the rest of the drive, which was longer than the drive to the store .
So here are the facts that I've collected:
-The noise sounds like engine noise, but it is NOT RPM dependent, it remains the same pitch no matter how fast the engine is running.
- The volume of the noise is constant and is not affected by the volume of the radio. So I can hide the sound by turning up the radio volume.
- The sound is only there when the engine is running.
- When the sound is there, it is there if the radio is on OR off.
- The noise is intermittent, sometimes it is there when I start the car and it slowly goes away. Other times it doesn't have the noise at all. I don't believe that I have ever had the noise appear while driving. If the noise isn't there when I start the car, then it doesn't show up at all until I shut the car off again. Usually once it is gone, it is gone for the day.
I'm open to suggestions on what may be causing this. And yes, I do have spark plug wires that have noise suppression, like I said it is not RPM dependent.
Thanks,
Ray
Thanks,
Ray
I hate intermittent problems. Not sure of what is going on but here is a site you can use to help you diagnose the problem: http://www.termpro.com/asp/pubs.asp?ID=121
Good luck with it and let us know how it turns out.
DC
DC
Gooday rbrock,
I've been having a FUN time with my system too.
Checkout my thread -Lotsa good advice.
http://forums.corvetteforum.com/c3-g...k-arrrrrr.html
Hope this helps,
Cheers,
GAV
Hope this helps,
Cheers,
GAV
