HILBORN EFI on a LS3?
Old 01-15-2012, 12:35 PM
Cab1
Cab1's Avatar
Default HILBORN EFI on a LS3?
Anybody out there using a Hilborn EFI on a LS3? What would be the advantage of using this set up? Would it be drivable on the street?
Old 01-15-2012, 03:52 PM
Gordonm
Gordonm's Avatar
Big question is why would you do that. The electronic is so much easier and will provide the same if not better performance.
Old 01-15-2012, 04:12 PM
Corey_68
Corey_68's Avatar
if he is talking about the moden LS3.
Cab are you talking about the GenIII LS3 or the LS3 Big Block from the early 1970's?
Old 01-15-2012, 04:56 PM
l88rocket
l88rocket's Avatar
Kinsler makes a intake for the LS engines, I just put there set up on an LSX 454 in a 33 ford. its a bad *** set up but wont fit under a hood thou, not without very short intake stacks
it is electronic and much better than a gm set up.
Old 01-15-2012, 05:01 PM
Gordonm
Gordonm's Avatar
Picture? Is it electronic or mech injection?
Old 01-15-2012, 08:30 PM
MrForce
MrForce's Avatar
St. Jude Donor '11, '14
it's electronic
Rob
Old 01-15-2012, 08:44 PM
Corey_68
Corey_68's Avatar
Looks amazing, question is it it worth the $6,500-$7,500.
http://www.hilborninjection.com/prod...=429&CatId=174
Old 01-16-2012, 12:03 PM
Cab1
Cab1's Avatar
I was talking about the moden LS3 - but I guess that answers my question. Why would you go back to old school gassers teck when the LS3 already comes with a nice tight little intake package?
Old 01-16-2012, 12:41 PM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
They are good for low 900 hp small blocks because they flow about 2000 or so cfm depending on the bore size.
The Hilborne and kinsler 8 stack EFI are wonderful units
Old 01-16-2012, 11:07 PM
l88rocket
l88rocket's Avatar
there not old tech, they flow more cfm and produce more power than any gm style intake.
Old 01-18-2012, 05:54 AM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
Originally Posted by MrForce
it's electronic
Rob
That sure is PURDY!
Old 01-18-2012, 10:16 AM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Sweet! I like the old school induction setups. Im running a modernized Tripower setup on my car.
Old 01-18-2012, 07:29 PM
l88rocket
l88rocket's Avatar
They also make a crossram set up that lays the runners on there side, It will fit under a stock c3(or should)
Old 01-19-2012, 10:57 PM
vettehardt
vettehardt's Avatar
I know it isn't an LS3, but here is a short stack electronic injection system.
Old 01-19-2012, 11:27 PM
72LS1Vette
72LS1Vette's Avatar
I think the price tag is why you don't see many (any) people here using them. Looks like Show Car/TV Show/Very Rich Guy technology. Most of us are quite happy with the way the stock LS fuel injection systems work, and they can be tweaked to produce more HP easily.
Rick B.
To HILBORN EFI on a LS3?
Quick Reply: HILBORN EFI on a LS3?
