3x2 bbl carbs converted to fuel injection?
someone mentioned to me this evening that they had either heard of or saw where 3 holley 2 barrel carburetors had been converted to throttle body injection so you would still have the look of carbs but the advantages of EFI. is this true or someones pipe dream? i would love to do something like this with my 78 someday if it's a possibility.
i actually saw a 58 Impala with a 348 and 6 stromberg 97's converted to TBI so i know it CAN be done, i just dont know if it's something that can be purchased off the shelf or if it's something i'm going to be using my extensive skills with a CNC mill and a lathe to do it myself?
I am sure its doable as I have seen dual 2bbl TBI units before. 2 are easier as the adapter plates have room on the intake. The 3x2 may have issues for the plates so you might have to drill the intake to take the TBI units to leave room for them.
The 2bbl GM TBI units are small so I don't think that would be the issue. That and a megasquirt 3 should be able to control them. Biggest issue is the intake from what I can see.
I'm not sure who is doing it but the throttle bodies are made to look like Holley carbs. check with Charlie price at vintage speed. i think he has a system that resembles the 2g Rochester, but he may know
a TIG welder and my CNC Milling machine ought to take care of the intake carburetor mounting pads. I converted a factory crossfire intake to use 2 4 BBL carburetors using a MIG welder and the mill. not only did it look good but the car ran like a bat out of hell.
YES! thats the one! thank you. as soon as i saw the name you typed in i remembered!
Why??? You have a 3x2 carb system on your car and want to butcher it??? Just sell it to someone who wants it. With the funds you can buy any FI unit you want....
no, I have a small block and i am thinking about going to a big block. i like the look and sound of the 3x2 setup but i really prefer fuel injection for the easier cold starting, better fuel efficiency, the list of reasons just goes on and on.
Give these guys a call:
http://www.fbthrottlebodies.com/
They do a Mopar 6 Pack EFI setup. Mopar used Holley 2300 carbs just like the tripower. They use a port injection setup so the manifold would have to be modified for the injectors. Vette magazine did a article on efi tripower using their throttle bodies. However, no real details. I was thinking of this as well for my planned small block to big block swap but decided to stick with carbs for now.
EDIT:
Here is a link to one of the Vette articles.
http://www.vetteweb.com/tech/vemp_11...est/index.html
It has links to the rest of the series. They modified a dual quad intake to EFI tripower. But no real technical details. One reason that I am really not a fan of the magazine.
EDIT:
