Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-28-2011, 01:47 PM   #1
corvette_stingray
Junior Member
Default 71 - 74 Corvette 454 Engine compartment size
1974 C3 Corvette 350 engine swap to 74 BBC 454 truck 3999289 casting number for 454 engine.
* understanding that the 74 Corvette was the last year of the BBC 454 LS4 engine with Auto TH400 Tranny.
The question is: on a 71 - 74 Corvette is the Engine compartment size the either if the car was a SBC 350 or BBC 454 from factory.
Second part to question: is the Corvette Engine compartment size on a 71 -74 Corvette difeerent from a 75 - 79 corvette.
Please help, as I'm ready to shoehorn a 74 Truck 454 engine (3999289) into a 74 Corvette Stingray.
Last question: should I use a Short Water Pump vs Long Water Pump?
Thanks in Advance to all,
New Member
corvette_stingray is offline   Reply With Quote
Old 12-28-2011, 02:32 PM   #2
HamadUP
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
HamadUP's Avatar
I believe engine compartment size is the same among the C3 years, so basically any C3 will be able to get a big block inside it.
You should use short w/p in that application, also you have to use a different oil pan and possibly intake.
HamadUP is offline   Reply With Quote
Old 12-29-2011, 11:59 AM   #3
Big Block Dave
CF Senior Member
Big Block Dave's Avatar
I could be wrong, but I beleive that the waterpump may also be Corvette specific, as opposed to standard short waterpump.
Personally I would spend the money in building a killer sbc before swapping in a BBC...its just a simpler package with a small block and far more convenient to work on....in addition to all the silly crap youd have to buy in bracketry and pulleys etc
Big Block Dave is offline   Reply With Quote
Old 12-29-2011, 03:03 PM   #4
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Quote:
Originally Posted by corvette_stingray View Post
...on a 71 - 74 Corvette is the Engine compartment size the either if the car was a SBC 350 or BBC 454 from factory...
Engine compartments are the same size.
Quote:
...is the Corvette Engine compartment size on a 71 -74 Corvette difeerent from a 75 - 79 corvette...
No.
Purchase the 74 assembly instruction manual (AIM) and follow the installation diagrams for the big block option. The AIM shows how they did it and will also list the various parts you will need for the swap.
You will need a big block radiator for cooling and big block front springs for the additional weight. Truck blocks are a little taller than passenger car blocks so you may need a low rise intake manifold for hood clearance.
Good luck.
Easy Mike is offline   Reply With Quote
Old 12-29-2011, 04:04 PM   #5
corvette_stingray
Junior Member
Default Gentlemen thank you soo much for all the advise and Help
Really has been helping me out, Happy New Years to all Corvette Lovers...
The Corvette is still American's Sexy Car...
Thanks again.
Old 12-29-2011, 04:15 PM   #6
Alan 71
CF Senior Member
Alan 71's Avatar
Hi c_s,
The only thing I'll add is that I believe the a/c option limits the room available for the engine since the blower duct work is larger then a non-a/c car.
This didn't stop the factory installation of a bb in any way, and may not affect you in any way either.
Happy New Year!
Regards,
Alan
Alan 71 is offline   Reply With Quote
Old 12-29-2011, 04:24 PM   #7
DRIVESHAFT
CF Senior Member
DRIVESHAFT's Avatar
FYI - Your block may have come out of a light duty truck, but its not what is considered a truck block.
Thats a good thing. Truck blocks are taller, heavier, and a general pain in the butt for no advantage unless your trying to build a major stroker.
DRIVESHAFT is offline   Reply With Quote
Old 12-29-2011, 04:28 PM   #8
RHD '68 L89
CF Senior Member
RHD '68 L89's Avatar
3999289 block was used in Vettes so all the factory bits should just bolt up.
RHD '68 L89 is offline   Reply With Quote
Old 12-29-2011, 04:46 PM   #9
corvette_stingray
Junior Member
Default Thanks for the info, this is great news
Thanks for the info, this is great news.
Old 12-29-2011, 04:47 PM   #10
corvette_stingray
Junior Member
Default This is great news
Quote:
Thanks for the info, this is very good to kown.
Old 12-29-2011, 09:15 PM   #11
Ben Lurkin
CF Senior Member
St. Jude Donor '09
Ben Lurkin's Avatar
You will need corvette specific pulleys and accessory brackets for your 454 as well as a short water pump. Somebody already mentioned the springs and rad. Add to this list a corvette specific oil pan and oil pump pickup tube. All these items will probably cost you $1200 or so.
GM never made the 454 in a tall-deck block; only the 427 and 366 md & hd truck engines came in that configuration.
I hope you are planning on rebuilding and doing some performance upgrades to that 454 before installation; otherwise you are going to be disappointed with it.
Ben Lurkin is offline   Reply With Quote
Old 12-29-2011, 09:44 PM   #12
scrappy76
CF Senior Member
scrappy76's Avatar
short water pump is a short water pump. There is not a corvette specific short water pump. I am also doing this swap and if you have patience in your search for the correct pulleys and brackets, it will cost less that $1,200. Also if you do some searching There are two others on here who have swapped in a light duty truck bb and used the same oil pan, but if you want the vette oil pan, I have seen a couple on ebay for a average of $50.
scrappy76 is offline   Reply With Quote
Old 12-29-2011, 10:47 PM   #13
Big Block Dave
CF Senior Member
My waterpump speculation is from many years of reading catalogs while sitting on the toilet. If Im wrong, please forgive me, but please tell me why a manufacturer would make two of the same part for an additional application specified for Corvette, with a different part number?
http://www.tuffstuffperformance.com/...od/prd9010.htm
http://www.tuffstuffperformance.com/...od/prd8951.htm
Old 12-30-2011, 03:12 AM   #14
HamadUP
CF Senior Member
St. Jude Donor '08
HamadUP's Avatar
simply because the corvette uses a different shaft diameter, I think it was 3/4 in. vs 5/8 in. for the passenger cars. If you want to retain the stock fan clutch then you need a corvette specific w/p with the larger shaft, so basically you could use any BB short w/p as long as you have the correct fan clutch.
Old 12-30-2011, 08:50 PM   #15
scrappy76
CF Senior Member
scrappy76's Avatar
Quote:
If you go on each of the following auto parts stores : Napa , Advance , or Rock auto , They all offer replacement water pumps for the 1974 454 big block in either 5/8 or 3/4 shaft. In different brands too. I am sure if you go with the 3/4 shaft, it is stronger than the 5/8.
Old 12-31-2011, 12:46 PM   #16
hugie82
CF Senior Member
I did a 74 with a 427bb and 4speed. Fit right in DrRebuild supplied all the brackets and mounts.
hugie82 is offline   Reply With Quote
Old 12-31-2011, 05:20 PM   #17
stingr4y
CF Senior Member
stingr4y's Avatar
For what its worth, I too dropped in a 454 with the truck oil pan. I didn't know to worry about it. It fit fine.
I even ran with all the truck pulleys for a while, (had to re-wire for alternator). No A/c, no power steering though.
stingr4y is offline   Reply With Quote
Reload this Page 71 - 74 Corvette 454 Engine compartment size
Tags
1974, 350, 454, 71, 74, ac, casting, compartment, comperment, corvett, corvette, corvettes, engine, swap, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
