confused on engine casting numbers
Old 11-27-2011, 09:44 PM
69cvette
69cvette's Avatar
Default confused on engine casting numbers
i have a 1957 chevy with a supposed 300 hp 327 in it but i wanted to clarify if it was true.
the block casting numbers read TIII56F
can anyone help me out?
I know the T stands for Tonawanda.
Old 11-27-2011, 10:21 PM
69cvette
69cvette's Avatar
also is a stock 327 a flat tappet cam engine?
is running valvoline 10w 40 good oil for it?
need some help on those casting numbers too
Old 11-27-2011, 10:25 PM
Mike Ward
Mike Ward's Avatar
That's not a 'casting number'- it's a machine code that I presume was found on the stamp pad at the front right side of the block.
T would be Tonawanda where the engine was built
1115 means it was built on November 15th, year unknown
6F is unknown, possibly a truck or marine installation, not a Corvette.
Old 11-27-2011, 10:34 PM
restoman1
restoman1's Avatar
Check the numbers again. You have one too many digits in there. It's probably T1115F or T1116F which would make a little more sense.
The "F" designation was used in the full size cars in 1955 (265/162), 1956 (265/170) and 1957 (283/185). (It was also used from 1958 to 1961 in the 348, but I doubt that's what you have.)
What's the casting number on the rear of the block? That will narrow it down a bit.
Ed
Old 11-27-2011, 10:42 PM
69cvette
69cvette's Avatar
i just tried to see if i could loo on the back of the block, ill have to look from underneath or something
Old 11-28-2011, 06:10 AM
Indiancreek
Support Corvetteforum!
Indiancreek's Avatar
It's on the bell housing flange on the top. SHould be able to be seen to the side and behind your distributor.
Old 11-28-2011, 10:29 AM
bmans vette
bmans vette's Avatar
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
http://www.nastyz28.com/sbchevy/sblock.php
Check out this site for help with id on your block.
Looks like the old mortec site is gone but the info looks good here.
Bman
Old 02-12-2012, 02:16 AM
69cvette
69cvette's Avatar
maximize the pictures to get the best view
alright i'm still trying to this day to figure out my casting number because I'm dying to know what engine i have and what it was out of, someone told me something crazy and that i might have a 283 because the number of 327's that came with powerpack heads was so much lower. do you think its a 283 from what you can tell and what I've provided?
any telltale signs of a 327 over a 283?
Old 02-12-2012, 08:22 AM
69cvette
69cvette's Avatar
i suppose this is really next to impossbile to tell just by looking without either pulling the head or knowing the casting numbers, ahh im so irritated i cant get to them.
Old 02-12-2012, 09:08 AM
Mark Riles
Mark Riles's Avatar
It seems as though you will have a hard time reading the casting number which as mentioned is stamped on the webbing of the bell house flange. Without that casting number your journey will not go much further. However, pull the valve covers and post the cylinder head casting numbers. Using those casting numbers we can determine what the heads are and possibly lead us to what they are on family wise.
Old 02-12-2012, 09:30 AM
69cvette
69cvette's Avatar
i've got people telling me it might be a 283 and now im starting to think it might be. and if it is im going to be VERY VERY upset, 283's suck.
Old 02-12-2012, 09:35 AM
Mike Ward
Mike Ward's Avatar
What's stopping you from reading the casting number and date?
Old 02-12-2012, 09:38 AM
69cvette
69cvette's Avatar
the fact that the back of the head is too close to the firewall get behind the engine, i've tried squeezing a camera to snap a picture but that wont work either. i dont even want to touch the car til i know what engine it has, i've never thought this could be so difficult and so frustrating in my life lol.
Old 02-12-2012, 09:39 AM
Mark Riles
Mark Riles's Avatar
Valve covers. 4 bolts each. Pull them and post the casting numbers of the cylinder heads. Also, try unplugging the wires and removing the distributor cap for more access to the casting number on the back of the block. A squirt of brake cleaner may help to wash away some of the grime that can sometimes hide the numbers. If you can get a rag or a brush back there it will help too.
Old 02-12-2012, 09:51 AM
69cvette
69cvette's Avatar
alright i may try that but here's the best pictures i could get with my camera
i see some stamping but that's not it and i don't think that helps me either.
but this is how close it is to the firewall. that's the edge of the valve cover. that's as far as i can see, its probably tucked away under the valve cover.
ill pull it some other day when its warmer.
Old 02-12-2012, 10:06 AM
L88Plus
L88Plus's Avatar
Bman
Mortec ain't gone, it just got archived...runs a bit slower but it's all still there.
http://web.archive.org/web/200805130...ec.com/bbc.htm
Old 02-12-2012, 10:26 AM
Mike Ward
Mike Ward's Avatar
There's tons of sites and books that will have all the info. The OP needs to put a bit of effort into cleaning and stretching.
To confused on engine casting numbers
Old 02-12-2012, 11:21 AM
69cvette
69cvette's Avatar
the best i could do was get a GM in the picture and i took over 30 pictures and got pictures of mostly nothing, its like being blind, i wish it wasnt so cold i'd pull the valve cover and look.
Old 02-12-2012, 01:28 PM
anips
anips's Avatar
I believe the casting # is under your throttle or kick down bellcrank, its not a stamping its a raised cast # for 64-67 327-300hp it would be 3791362, #'s vary between what yr. if you pull the valve cover the casting # you will get is the head casting # which will help to identify if its a 250 or 300 hp, its time to get dirty.
Old 02-13-2012, 08:40 PM
69cvette
69cvette's Avatar
okay well i think I've finally figured it out without looking at the casting numbers
i read the engine number on the front wrong and it was TII5GF NOT 6F
i looked up GM suffix codes and this is what I got
GF 1955-56 265 162 MT B, A/C
GF 1957 283 250 TG B, FI
GF 1965-67 283 195 PG
195 earth rumbling horsepower!!
its a far cry from 250 HP lol
give me all the more reason to tear this 283 out ASAP
Quick Reply: confused on engine casting numbers
