Spark Issue
Spark Issue
Last week I installed a new distributor, cap, and coil. Now there is a very audible spark from number 8. Pulling the wire off does not stop the spark and neither did using a different cap. If you put a mechanics' stethoscope to the base of the number 8 post you can hear it loud and clear. It seems to be beneath the cap and its only on number 8. Any ideas/suggestions for the cause?
Discovered this to be the culprit. Decided to put in the coil from the distributor I took out because I knew it wasn't sparking. Also put in the spring and rubber ring and started the car and no sparking. I then put the brand new coil back in and started it up again and still had no spark.
