77 c3 radiator r&r
77 c3 radiator r&r
I changed my water pump but the radiator has a slight leak too. I want to pull it and send it out. (I haven't put the fan on yet) The service manual says nothing about this. Do I have to pull the hood as I am alone here? Please let me know if it is the same as most other GM cars. Pop the top caps and bottom bolts and hoses and out she goes or is there more in a 77 Vette?
I am replacing every old part that can cause a possible breakdown. I am not making a car with all GM parts, sorry, I can't afford it. But all parts that I am using are made in the USA. If the box doesn't say it, I don't buy it.
Jack
77 L82
Jack
77 L82
I replaced the radiator on my '79 without removing the hood by myself. It wasn't the easiest job, but if you take your time you should be fine. I had read you would need to remove the shroud before you remove the radiator, but while working on mine the radiator came out just fine once I pushed the shroud back toward the engine.
Radiator R and R
Yes, one can do it by themselves, but it is a whole easier and safer to both you and the car finders for two do the job. Hints,
- Hood off, clearance for lifting and getting the radiator to pull straight up
- Remove bolts under fender holding the core support and tilt forward max
- You can pull the radiator with the shroud in, but it is easier to pull both and reinstall both together.
No how you cut it this is a job.
I was pleased by core support had only surface rust so cleaned it up, painted and now working on the engine.
1:Can't afford it,
2:your using only USA parts.
So this means you wont be buying anything at the local parts store and will send off for everything?
Good luck with that.
For example, I just paid $35.00 for a new old stock AC Delco water pump. So I am taking my time. I am sick of doing jobs 2 & 3 times. I say that I can't afford it because I have 10 other cars that I have to maintain too. They all get parts made in the USA. (Except for the Jaguars & Porsches).
So it's not really an oxymoron.
