Water Pump to crank belt needed???
Correct, I used to have AC also so I have the same pulleys as you.
My first trip to the parts store (probably) got me the correct crank/WP belt for non-AC pulleys, and it was way too small. 2nd, 3rd, 4th trip we figured it out. I could probably do with the belt being 1/8" shorter, but it fits pretty well as is.
I'll get you the brand and part # tonight and from that you can decode the sizing. Then any decent parts house (which is to say not Autozone) can cross reference belts based on the dimensions.
And maybe even a more complicated question, does it matter if you have the water pump to crank belt? I ask because once you remove the AC and that AC belt, it also removes the belt contact area which aided in turning the pulley's, right? That is what prevented belt or pulley slippage, right?
Perfect! I'll got to NAPA and see if we can't come up with a belt with the data you provide.
Like I said, some people have problems and some don't. It takes a certain amount of torque to spin the WP, and it's hit or miss as to whether or not that little section of the alternator belt can apply that torque without slipping. I ran for years without the crank/WP belt, and I never had problems with slippage. But I always kept my pulleys very clean and the alternator belt very tight. I was never comfortable with driving the water pump like that though, so I tracked down a belt when I redid my cooling system.
Thanks to all who assisted with this issue. BK can you send me that pic via email?
vette79c3@verizon.net
http://www.autopartstomorrow.com/par...rs/234808-belt
Here's a pic of the fitment.
wcsinx that looks like a nice fit and you can't go wrong with gates belts and hoses.does your car feel any different with the addition of the extra belt?do you think it robs some power?aside from the squeal did you feel more secure because you have a backup pump belt?sorry for all the questions but i'm curious if guy's are doing this for different reasons.
Nope and nope, parasitic loss due to the WP is theoretically unchanged because I had no slippage before. I suppose there's a tiny bit more drag simply from rolling another belt around, but I doubt it would even be measureable.
Yes
It just didn't feel & look right to have the WP driven by such a small footprint of the alt. belt. The stock non-AC configuration does indeed have that crank/WP belt.
Yes
#34
jerome, wcsinx provided a belt part# and link from Crank to WP a few comments above. If that works for him and our configuration is similar then I'm going to purchase it and try to install.
#37
I have a '79 L82 4 speed without AC (original). When I bought the car 2 years ago, it had less than 10k miles and all original belts. I still have the crank to WP belt and the GM part number on it is: 3935420.
This Zip belt is the one that matches the current belt (so they say).
Here is a pic of the layout: The center belt is the old crank to WP belt discussed. Hope it helps.
#38
#40
