Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-01-2002, 12:46 AM   #1
GrandSportC3
CF Senior Member
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03 & '06
GrandSportC3's Avatar
Send a message via AIM to GrandSportC3 Send a message via Yahoo to GrandSportC3 Send a message via Skype™ to GrandSportC3
Default flywheel or flexplate?
That may be a stupid question but I would like to know exactly what the difference between a flywheel and a flexplate is.
It is my understanding that a flexplate is used in combination with automatic transmission and a flywheel is used for a manual transmission. Is this correct?
Why are flywheels much more expensive than flexpates?
thanks
Olivier
GrandSportC3 is offline   Reply With Quote
Old 05-01-2002, 01:38 AM   #2
bbeck
CF Senior Member
bbeck's Avatar
Send a message via AIM to bbeck Send a message via Yahoo to bbeck
Default Re: flywheel or flexplate? (GrandSportC3)
My understanding was always that a flexplate is for an Automatic tranny, and a flywheel is for a Manual. But, when looking to buy people don't always use the same terminology, so be sure to check.
bbeck is offline   Reply With Quote
Old 05-01-2002, 01:51 AM   #3
fauxrs
CF Senior Member
fauxrs's Avatar
Flywheels are for manual transmissions they're weight can vary greatly depending on the material - billet steel, cast iron, aluminum.
Flexplates are used exclusively for automatics and are generally a piece of stamped steel with a ring gear welded on.
Like all car parts quality varies widely.
Price is obvious, which is cheaper , a 35 pound slab of billet steel or a stampied piece of 10 gauge galvanneal with a ring gear weldedonto its curcumference.
fauxrs is offline   Reply With Quote
Old 05-01-2002, 08:33 AM   #4
GrandSportC3
CF Senior Member
Default Re: flywheel or flexplate? (fauxrs)
>>curcumference.
Thanks for the information! However - I have one more question:
When I purchased a "external balanced" engine for my 69 (sold) I had to use another flexplate because the engine was a 383 instead of a 350.
Is this the same way for flywheels or can I use my current flywheel when purchasing a engine with a different size crank (externally balanced)?
Olivier
Old 05-01-2002, 10:35 AM   #5
vettfixr
CF Senior Member
vettfixr's Avatar
350 engines are internally balanced ( 0 balance) while 383 engines are externally balanced (offset or out of balance). I'm not sure if I'm using the right terminology here but a 350 engine requires a flywheel or flexplate that is in perfect balance (0) while a 383 engine, due to the use of a 400 crankshaft must have a flywheel or flexplate that is offset balanced by a certain number of ounces. I believe the reason for this is because the larger pistons in a 400 engine would require crankshaft counterweights that are too big to be accomodated by the engine case. The flywheel or flexplate for a 383 or 400 engine typically has a weight welded to it to throw it out of balance the correct number of ounces. Like everything else there are exceptions to the rule. You can get a 383 or 400 assembly that is internally balanced through the use of heavy metal (Mallory metal) and then use a zero balance flywheel or flexplate. Flywheels and flexplates also come in different sizes and different tooth counts (153 vs 168) that require different starter nosepieces. This just keeps life interesting. :)
[Modified by vettfixr, 9:38 AM 5/1/2002]
vettfixr is online now   Reply With Quote
Old 05-01-2002, 11:10 AM   #6
fauxrs
CF Senior Member
fauxrs's Avatar
[QUOTE
Olivier
[/QUOTE]
On any externally balanced engine you will need the correct balancing device at either end of the crank - since your 383 is based on a 400 crank - externally balanced - you will need a harmonic balancer from a 400 and a flywheel or flexplate from a 400.
Internally balance motors use neutral balanced componants so a 350 flywheel/flexplate should NEVER be used on a 400 crank. Also know that the newer 350s, I dont remember where but starting perhaps with the LT1 in the c4 vette are also externally balanced.
Reload this Page flywheel or flexplate?
Tags
balance, corvette, difference, engine, external, flex, flexplate, flexplates, fly, flywheel, flywheels, neutral, plate, versus, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help!! A new block or get a retro roller setup?? kpforce1 C4 Tech/Performance 11 07-07-2004 12:09 PM
400 small block 153 tooth flywheel MikeM Engine Mods 20 12-07-2003 12:06 PM
To stroke or not to stroke. That is the question timallard C4 Tech/Performance 11 12-06-2003 02:42 PM
Choosing a new engine - ZZ4 or AR Racing Engine. Any recommendations??? buchinsd C3 Tech/Performance 23 10-12-2003 02:48 AM
Rebuild dilemma 427 or 454 marky mark Engine Mods 19 07-25-2003 04:06 AM
are our engines internaly or externaly balanced? OkeeGuy C3 Tech/Performance 17 01-24-2003 07:42 PM
To 383 or not 383, that is the question. So what's the answer? joeveto C3 Tech/Performance 44 05-12-2002 12:28 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
